Slides
Discussion in 'General Camping Discussion Forum' started by keiper, May 14, 2016.
  1. keiper
    keiper Gotta get out there!!
    23
    May 8, 2016
    Whats the best way to keep these smooth and as far as preventative maintenance goes what should i be using if anything. [​IMG]
  2. Haybale
    2,480
    302
    Aug 22, 2013
    San Diego via MN
    They are called lift posts, I used the spray silicone... Worked for me!
  3. Snow
    10,108
    1,028
    X2 on what Haybale said .. spray silicone couple times a season ... Just try to avoid getting the spray on the material .. Use to use a flat cardboard behind the lift post when spraying ..
  4. keiper
    23
    May 8, 2016
    Copy that. Spray lift posts with silicone spray
  5. Dubbya
    6,129
    52
    Aug 2, 2011
    Steinbach, MB
    Yep, dry silicone lube spray. Hold a piece of cardboard between the lift post and tenting to prevent getting the lubricant on the vinyl fabric and use a rag to wipe off excess.
  6. Milktrk
    Milktrk New Member
    331
    Apr 17, 2014
    I apply the silicone to the pulleys on the inside of the lift post making sure I don't get the silicone on the canvas. I then wipe off the overspray and use a stainless steel cleaner to keep the posts clean.
