Slipping or missing gear tooth when raising/lowering
Discussion in 'Roof/Floor Repair & Maintenance' started by Curds301, Mar 18, 2021.
  1. Curds301
    Curds301 New Member
    Mar 10, 2021
    **Edit: I accidentally posted in this forum vs lift systems sorry**
    Hi All,
    We have just picked up a 2004 Fleetwood Carmel which is in really nice condition, aside from the mechanism to raise/lower the top. It feels and sounds like there is either a misalignment, sipping or missing gear tooth that makes a "ping" sound every few rotations of the crank.
    My question is, how accessible are the gears for this system and has anyone replaced or fixed a similar issue?
  2. j3rry
    j3rry New Member
    Sep 18, 2017
    im not sure if its the same or not, but I found out that the pin that holds the "tooth" for the ratchet was compromised. this caused the tooth to be out of alignment and only catch on one corner. This would make it skip every once and a while, then eventually this caused a complete failure of the lift mechanism. all I had to do was take the pin out and run a bolt through that held the pin at the proper angle.
