We have a Dometic fridge in our 2008 Fleetwood Arcadia, and we just run it on propane when camping for 2 weeks without power. It uses very little power--the water pump and heater use FAR more. I bought a 100 watt solar panel and charger which makes my batteries last for 2 weeks of camping while running the fridge the whole time on propane, using lights (LEDs), water pump for showers (for the 6 of us), and occasional use of the heater.Domestic not really new, it's a 2011 aliner, we're 3d owners.
You mean a battery charger?We have a Dometic fridge in our 2008 Fleetwood Arcadia, and we just run it on propane when camping for 2 weeks without power. It uses very little power--the water pump and heater use FAR more. I bought a 100 watt solar panel and charger which makes my batteries last for 2 weeks of camping while running the fridge the whole time on propane, using lights (LEDs), water pump for showers (for the 6 of us), and occasional use of the heater.
Yes. If we we were just using the fridge on propane, we wouldn't need it (since the electrical draw of the fridge when running on propane is quite small), but it's the frequent use of the water pump and heater that pull down the battery charge. The solar panel (even when shaded most of the day) puts enough charge back into the batteries that we last 2 weeks with no problems.You mean a battery charger?
I love that, I'm glad it works well for you, I'm sort of on my own about figuring this stuff out, but I'll probably end up with a small as I can generator, only really want the fridge to stay working.We camp where solar works well, so have a Zamp 160 solar panel, which charges our batteries. We switched to dual 6v batteries when a single group 24 was not quite enough for some days in the TT. The deep cycle golf cart batteries can be drained lower than the standard group 24 without shortening the life.
the water pump and furnace are the most piggish. We do have a ceiling fan with a PWM control, so we can run it while dry camping. Works great in hot weather to keep air moving.
The fridge is 2-way, it does last a long time on propane, but needs battery for controls and ignition, as does the water heater.
if we camped where solar didn’t work well, we might get a Honda or one of the small, quiet, efficient generators.
You would be surprised how easy it could be to run a small solar setup and the people here would be with ya with any questions, no fuel, no noise.I love that, I'm glad it works well for you, I'm sort of on my own about figuring this stuff out, but I'll probably end up with a small as I can generator, only really want the fridge to stay working.
OMG just seeing your in Minnesota? The wife and I just rolled into Rochester! Just here for a day or 2 then back to Michigan.I love that, I'm glad it works well for you, I'm sort of on my own about figuring this stuff out, but I'll probably end up with a small as I can generator, only really want the fridge to stay working.
ALP makes a 1000watt Inverter generator that only runs on propane. You can run it for hours on a green disposable propane bottle of connect it to a bigger tank. Small and lightweight to handle and use. We sold our ALP because we wanted a generator that would run our a/c.I love that, I'm glad it works well for you, I'm sort of on my own about figuring this stuff out, but I'll probably end up with a small as I can generator, only really want the fridge to stay working.
Ah, a newer fridge. Not sure but it shouldn't need a ton of batterie power. What feidge is it?
I believe @Sjm9911 meant a newer design, not necessarily newer in age. The older designs would run on propane with no electricity at all required.Domestic not really new, it's a 2011 aliner, we're 3d owners.
We do run it on propane, but it needs battery power as well.
If yours is a newer design with a control board and automatic ignition it should still only draw ~10W when operating. Check the fridge manual.How do you know how many watts you need?
I bought a 100 watt solar panel and charger which makes my batteries last for 2 weeks of camping while running the fridge the whole time on propane...
We camp where solar works well, so have a Zamp 160 solar panel, which charges our batteries. The fridge is 2-way, it does last a long time on propane, but needs battery for controls and ignition...
You would be surprised how easy it could be to run a small solar setup...
As others have mentioned, a portable solar panel should keep the fridge working more or less indefinitely (on propane mode)....only really want the fridge to stay working.
How did you like the ALP?ALP makes a 1000watt Inverter generator that only runs on propane. You can run it for hours on a green disposable propane bottle of connect it to a bigger tank. Small and lightweight to handle and use. We sold our ALP because we wanted a generator that would run our a/c.
Okay, how about one more opinion. The Hondas have a good reputation. I opted for a Champion, mostly because it's dual fuel. Gasoline is pretty expensive, plus there's the problem of fuel going bad if it sits for too long (yes, I've been guilty of that). LP will keep for a LONG time. And you don't have to pay the road tax on it. Also, doesn't stink things up like gasoline.I'm sure we need a generator, we have a small fridge, that's pretty much all I really want it for, isn't a small Honda enough to charge a deep cycle battery that will fit the bill for that need? I know their expensive but I do want the quietest one we can get. I would appreciate your input!
Like this? https://www.macfarlanegenerators.co...ack-battery-charger-with-amp-meter-gxh5055amp (PDF attached in case the website changes)slightly off topic, but parallel, not a tangent.
Are there any commercially available, liquid or gasseous fuelled, 12VDC electric generators?
12VDC gensets are not popular because the winding have to be 10 times larger. With a 1200W genset you are only pushing 10A @120V, but 100A at 12V. That much copper is expensive (and heavy). Cheaper to just make it at 120VAC and use a high efficiency multi-stage programmable charger.It seems that most* camping generators are used to replenish the trailer battery, and that can be done without having to make 120VAC, then rectify and transform that to the 13-ish volts of DC.
You can use a 4 pole alternator and spin your genset at 1800 rpm. Although quieter it does make them larger, heavier and more expensive (need ~twice the engine size to make the same power at half the speed).It also means a (non-Inverter) generator wouldn't have to spin at 3600 rpm to make 60 cycle AC frequency since the alternating current isn't needed.
The 12VDC output on those generators is not really optimized for deep cycle battery charging. It is more meant for boosting your vehicle battery if you run it down.There are AC generators galore from which to choose. There are fewer, but still many, with 12 VDC in addition to the 120 VAC, but I'm asking about 12VDC only.
So I'd need a different connector for thee 2 to work? Adapter? Is that right?ALP makes a 1000watt Inverter generator that only runs on propane. You can run it for hours on a green disposable propane bottle of connect it to a bigger tank. Small and lightweight to handle and use. We sold our ALP because we wanted a generator that would run our a/c.
It seems that most* camping generators are used to replenish the trailer battery, and that can be done without having to make 120VAC, then rectify and transform that to the 13-ish volts of DC. It also means a (non-Inverter) generator wouldn't have to spin at 3600 rpm to make 60 cycle AC frequency since the alternating current isn't needed.
* those that want the option of running the camper's air conditioning know who you are
I have three generators, but unlike Goldilocks none are 'just right'.
Champion 4500 (4kW) 3600 rpm 120/240 VAC as back-up at home
Briggs&Stratton 2000 (1.6 kW) variable speed Inverter to 120 VAC, plus 8A of 12V DC as backup for the Casita
Nissan 650 (.6 kW) 3600 rpm to 120 VAC, plus 10A of 12V DC as backup for the Coleman
