smarter tools 2000w overload alarm
Discussion in 'Miscellaneous Repairs & Maintenance' started by Bottom End, Jun 7, 2018.
  1. Bottom End
    Bottom End Member
    35
    Aug 22, 2012
    Hi Everyone
    I have a smarter tools 2000w generator and the overload alarm just started coming on. I have nothing plugged into the generator.
    It starts and runs just fine, but will not output any power.
    I have done all recommended maintenance.
    Any suggestions will be greatly appreciated on how to fix the problem.
    Thanks
  2. jnc
    3,931
    1,186
    Oct 1, 2014
    South Central New Hampshire
    Check the low oil cutoff switch. I have had a few genny's that this was the problem.
  3. nineoaks2004
    8,045
    3,585
    Dukes, Fl
    If the low oil alarm is not causing the problem. You might want to start it and let it run for awhile to dry the windings, I just did this to a friends unit, after about an hour everything dried out. You are supposed to exercise a generator at 1/2 load for about 45 minutes every month, this keeps the windings dried out.
