Smoke Detector
Discussion in 'Campsite Electronics' started by Jimbow, Mar 2, 2013.
  1. Jimbow
    Jimbow Well-Known Member
    1,787
    360
    Nov 30, 2012
    I noticed there isn't one in my ntu pup. I was planning on picking up a simple first alert and mounting (double sided tape?) it to the ceiling. Anything I should consider?
    Sent from my iPad using Tapatalk HD
  2. Twisty
    Twisty New Member
    4,375
    Aug 24, 2008
    Hillsboro, Oregon
    Put it in the opposite end or corner from the stove.
    Ours goes off when cooking or making coffee if the windows are not open far enough [:(!]
  3. Jimbow
    1,787
    360
    Nov 30, 2012
    I was considering placing it next to the AC, but not where it would be blowing on it.
  4. tombiasi
    6,324
    1,916
    Get a combo, smoke/CO if you don't have a CO detector already.
  5. Campit
    Campit EAT SLEEP CAMP
    1,638
    Sep 16, 2011
    X2
    Campit
  6. Jimbow
    1,787
    360
    Nov 30, 2012
    We have a CO detector low by the floor. I need to check, I think it may do propane also. But since smoke rises, I assume it won't help much in a fire.
  7. tombiasi
    6,324
    1,916
    CO is slightly lighter than most air. Since it is usually a product of incomplete combustion it is usually rising. Near the floor is OK if it needs to be. Smoke doesn't rise, warm air does. The smoke detector should be on the ceiling, or on the wall 1 foot down from the ceiling and away from any air currents that would wash it with clean air.
    Propane detectors should be low.
    Tom
  8. Jimbow
    1,787
    360
    Nov 30, 2012
    Thank you.
  9. tombiasi
    6,324
    1,916
    You are welcome. Be safe.
  10. Unstable_Tripod
    14,279
    48
    May 20, 2008
    Seattle, Washington
    In my TrailManor the combo LP/CO detector is near the floor and the smoke detector is on the ceiling.
  11. daveo1289
    daveo1289 Well-Known Member
    1,014
    140
    Apr 24, 2012
    Rochester NY
    Ditto on the Jayco.
  12. tombiasi
    6,324
    1,916
    LP detectors draw a lot to use internal batteries so they are usually hardwired near the convertor.
  13. Jimbow
    1,787
    360
    Nov 30, 2012
    On my Coleman it is in the dinette, across from the stove. When I open it today, I'm planning on seeing if it is CO and propane.
  14. Unstable_Tripod
    14,279
    48
    May 20, 2008
    Seattle, Washington
    BTW, many folks may not realize that some of these detectors, especially the combination one, have a limited lifespan. I have the Safe-T-Alert brand of CO/LP detector and it has a lifespan of five years. The date is printed in red on the back of the device.
  15. tombiasi
    6,324
    1,916
    The more recent ones will have built in timers that will notify you and then quit.
