solar controller location - advice needed
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by northpoletim, Jun 4, 2019.
  1. tfischer
    tfischer Well-Known Member
    3,408
    919
    May 21, 2014
    We put the controller near the battery. I have a "solar suitcase" that was intended to have it at the panel, but it's more efficient to run the higher voltage from the panel back to the controller near the battery. Since the intent is to charge the battery, there's no need to bring it inside to the converter.
  2. Anthony Hitchings
    295
    99
    Mar 2, 2019
    Don't fret too much on using wire gage over 12 (i.e. 10 Ga), our wire runs are short and charging currents not so high even under good conditions if we are talking 200W panel tops from our installation (I have 100W fixed an 100W portable).
  3. tfischer
    3,408
    919
    May 21, 2014
    I happened to have some leftover landscape lighting wire (10 gauge) so it worked out good that way.
