Solar Panel Transportation
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Econ, Sep 4, 2021.
  1. Econ
    Econ Well-Known Member
    1,443
    883
    Aug 18, 2019
    Deep South
    Can anyone come up with a reason that solar panels should not be carried on the A frame of a camper in a vertical orientation if cushioned from the road vibration with foam rubber? This would free up TV space.
  2. rsdata
    rsdata Active Member
    282
    103
    Oct 3, 2011
    N. KY
    sure why not? let us know how it works. I would purchase cheap foam mattress pads from Walmart or such to use as cushions front/back and bottom and help lock it into position.
    Econ likes this.
  3. Dingit
    Dingit Well-Known Member
    1,768
    1,246
    Mar 8, 2017
    They're sturdier than they look. Just don't sling 'em around by the wires. :)
    Econ likes this.
  4. LjohnSaw
    849
    57
    Jun 24, 2011
    Northern California
    Why not permanently attach them to the roof and be done with it? If you mount them cross-ways with a hinge at the peak of the roof, you could make it adjustable to point forward or backward at the campsite depending on the sun's location.
  5. Anthony Hitchings
    2,918
    1,697
    Mar 2, 2019
    Oakland, California
    my extra flexible 100W panel is glued to the roof, worked fine so far
    my rigid panel, which is "portable" lives on the home-made rear privacy "shelf" in our Jeep, though it could be inside the closed Aliner if need be.
    Do not permanently put a rigid panel on your roof if at all possible - its extra lift weight for the springs (and you) - and their anchorages
    Econ likes this.
  6. Jenkamus
    Jenkamus Active Member
    239
    69
    Oct 17, 2015
    Surprise, AZ
    My 100w panel is mounted to the roof. We have it screwed into framing but no issues here.
  7. Chris I
    Chris I Member
    79
    51
    Sep 2, 2020
    Portland, OR
    That still really limits your options for chasing the sun with the panels. I use a 10ft extension cable, and that allows me to move it around the site. Even partial shade on the panels will drop the watts collected by 50% or more. So unless you really like parking in full sun all of the time, it's best to keep them off the roof.
    Econ likes this.
  8. Colewood Fleetman
    Colewood Fleetman New Member
    May 15, 2020
    Colorado
    We used 3M VHB tape (not the stuff you get at Home Depot…not strong enough) to mount our 100w panel to the roof skin on our 04 Yuma…yes, it adds weight to the lift mechanism but it seemed to be the best option.
    Four years that thing has been up there, and has not come off in ANY weather! 60mph New Mexico cross winds? Nope. Tornado producing storms at home? Nope! Have to say, I was skeptical when reading about using TAPE to secure a flat, sail-like, 40lb panel. But, the science said it would hold, and others had done it with no issues. Just clean clean clean everything the tape is going to touch and let it sit for a few days to fully bond. Then, no roof holes ‍ and your panel is safe and secure. Now, it’s on to a new owner and she knows to keep an eye on it, but not to worry.
    SteveP likes this.
  9. theseus
    theseus Living the Darkside... Silver Supporting Member
    3,310
    765
    Feb 6, 2007
    Centerville, OH
    I think horizontal would be a better option ;)
    Using quality VHB tape, like @Colewood Fleetman did is an excellent option. A lot of TTs have Solar attached like this with no problems. I used z-mounts on my solar panel on my TT and a lot of dicor.
  10. Econ
    1,443
    883
    Aug 18, 2019
    Deep South
    Thanks for all the responses. I live in the Deep South. We do not voluntarily park/camp in the sun. We merely transport the panel to the campground and are looking for a way to free up TV space.
    This is an Aframe at 142 pounds I am the lift system. <<GG>>
    50' of 10 gauge extension cord of various lengths.
    Chris I likes this.
  11. kitphantom
    13,165
    2,247
    Probably depends on how you can attach it for travel. We have two solar systems, the original Goal Zero set with 4 panels that clip together and the Zamp, which folds and goes in its case. We sometimes transport the Zamp in the bed in our TT, but it mostly travels in the backseat area of the truck, with the fold-up seats it is a great cargo space, and the solar panel stands on the long edge so doesn't take much space. The other panels are stashed in an otherwise less-than-useful space under one dinette bench, which takes a bit of work to get them out and put them back, but it's OK. If we're moving from one dry camp to another, we'll just stand the assembled GZ set next to the Zamp in the back seat.
    We have chosen not to install our panels, because it gives us more flexibility in placement, since our trailer may often be in shade, and we can orient the panels out in the open.
    Econ likes this.
  12. Dingit
    1,768
    1,246
    Mar 8, 2017
    I've gone a couple thousand miles with mine dropped in the bed of a pickup between a slide-in camper and the front of the bed. Every so often they'd get picked up by the wind and start to rise...so we don't do that anymore unless it's a short drive. (Moving panels between 2 RVs is reason enough to avoid a permanent mount. But it has been very rare that we've put panels on the roof so that's another reason.)
    Econ likes this.
  13. McSkippy
    McSkippy Active Member
    162
    145
    Sep 10, 2019
    Colorado
    I think he was asking about transporting them, not deploying them, hence the title of the post.
    Econ likes this.
