Solar Panels Installed
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by PopUpSteve, Oct 12, 2021.
  1. PopUpSteve
    PopUpSteve Administrator
    19,915
    2,755
    Dec 22, 2002
    Malvern, PA
    I got my two flex panels on the roof last week. Still routing the wiring and have to mount the charge controller but they're working. I'll post some better photos and a more detailed account shortly.
    This first photo is pre-mounting, just marking the positions.
    Post Tape-Down. These aren't going anywhere!
    Strawhouse, rth3775, firepit and 4 others like this.
  2. Annunzi
    Annunzi Active Member
    165
    137
    Jun 14, 2019
    Vancouver Island, British Columbia
    Looks good! what type of tape did you use, VHB? I'm curious to know how you route the wires, my concern would be they don't get pinched/caught each time the pup is raised/lowered.
    ltatlock likes this.
  3. PopUpSteve
    19,915
    2,755
    Dec 22, 2002
    Malvern, PA
    I used EternaBond RoofSeal White 3" x 50' on the outside and 3M 1/2-5-RP32 VHB Tape 0.5 in width x 5 yd length for the backing.
    I didn't want to drill through the roof or sidewall of the camper so I made a quick connect at the end of the cables from the panels and routed a cable from that point under the roof lip and over to where the wires for the ceiling lights and used that pocket in the canvas to bring the cables down. Then I bring the plug to the AC power hatch and into the camper. I'll have photos and complete parts list soon.
  4. jmkay1
    6,872
    3,878
    Just curious why you chose that particular placement on the roof. I would have thought you would want it closer to the battery.
  5. PopUpSteve
    19,915
    2,755
    Dec 22, 2002
    Malvern, PA
    The charge controller had to go inside and the placement of the wires as noted above kept the look fairly clean when open.
    Sjm9911 and jmkay1 like this.
  6. Arruba
    Arruba Well-Known Member Gold Supporting Member
    671
    348
    Nov 28, 2014
    Central Oregon
    Looks good. I would not have thought of VHB tape. Thanks for the tip.
  7. PopUpSteve
    19,915
    2,755
    Dec 22, 2002
    Malvern, PA
    I routed a cable under the roof lip and over to where the wires for the ceiling lights are located. I used that pocket in the canvas to bring the cables down.
    Then I bring the plug into the camper through the AC power hatch.
    The other line coming out of the hatch is the temporary line from the charge controller to the battery. That will be replaced with a permanent line along the underside of the camper and up to the batteries.
    This line gets disconnected at both ends and is tucked away with the canvas when the camper is closed. Then a shorter line is used to keep the batteries charged when the camper is in storage.
    Sjm9911 and SteveP like this.
  8. SteveP
    2,246
    923
    You've probably already got this covered, but a connector at the bottom of the wiring pocket would allow you to to simply push the remaining wire back into the mouse hole instead of having to fold it into the canvas, and the wire through the mouse hole could be long enough to reach the drops from the panels, reducing the overall number of connections when down. The leads to the controller could be permanently attached for reliability.
  9. PopUpSteve
    19,915
    2,755
    Dec 22, 2002
    Malvern, PA
    Yup, the piece that is in the wiring pocket is only 10ft long. So it's connection to the inside wire is just inside the mouse hole (good nickname). I pull the inside connector out of the mouse hole, make the connection, and push it back in so the connector does not get wet. I wanted to leave enough of the outside wire exposed to be able to form a drip-loop. Since the skin of my camper is metal, I can use magnet hooks to position the wire for a drip-loop.
  10. Susan Premo
    Susan Premo Well-Known Member
    623
    334
    Nov 5, 2020
    Minnesota
    Do you get purple Martin's in your bird house? They're great to watch.
  11. PopUpSteve
    19,915
    2,755
    Dec 22, 2002
    Malvern, PA
    No tenants in the bird house, the rent is too high.
    Sjm9911, Strawhouse and jmkay1 like this.
  12. PopUpSteve
    19,915
    2,755
    Dec 22, 2002
    Malvern, PA
    In getting ready for the road, I found one mistake I’ve made. I went to clean off the panels and found it very difficult to reach the whole panel. I should have put them on opposing sides.
  13. BillyMc
    BillyMc Well-Known Member
    2,269
    1,597
    Mar 25, 2018
    I was thinking you must be really tall when I was looking at the one in the middle.
    If you are in their breeding zone you may want to put the house higher or in a more open area. They will use one as low as 10', but if there is surrounding stuff it needs to be higher.
  14. azwildcat
    azwildcat New Member
    Sep 19, 2021
    Glendale, AZ
    i was just thinking of adding solar to mine, and just like you i don't want to drill into my roof, i don;t know about you but my pup has to stay outside and i don't have a cover, how would it be protected from rain, hail, ect, so i've been looking at portable foldable solar panels kits on amazon, dos anybody have any experience with these, good or bad
  15. Anthony Hitchings
    2,896
    1,676
    Mar 2, 2019
    Oakland, California
    Four our vacation mode, the ability to charge from sunlight while driving on long days out here in the SW is helpful. You may not need that.
  16. PopUpSteve
    19,915
    2,755
    Dec 22, 2002
    Malvern, PA
    I went the portable route, even did some mods to the camper to tie-down the panel to the roof, both open and close (see: New Tie-downs for Solar Panel). I'm not the most trusting soul so I never wanted to just leave the portable panels on the ground thinking they would be stolen. They also only lasted about 2 years for me, between folding/unfolding and being left exposed to the elements.
  17. gladecreekwy
    1,505
    2,296
    Sep 25, 2016
    Jackson Wyoming
    This has been working well for us. Keeps our two group 24 batteries topped off. We don't use much power. We have a pup and a TT so we can use for either
    https://www.popupportal.com/threads/simple-solar-set-up.128482/#post-1333315
