SOLVED Placement of brake controller for electric brakes
Discussion in 'Tires / Brakes / Bearings / Axles' started by Anthony Hitchings, Jun 18, 2020.
  1. Anthony Hitchings
    1,235
    573
    Mar 2, 2019
    for a Primus IQ controller, bought via Amazon
    The Jeep Liberty, 2008, has very poor knee room. As of now I cannot seem to find any reasonable location for the controller where its in the right position, not in our knees, and I can see/operate the thing. Its very frustrating.
    I already moved the OBDC plug sideways to make room for one knee-banging location.
    If y'all have any good ideas, let here them.
    One option is to use a different brand of controller with different ergonomics/mounting.
  2. Jimbow
    Jimbow Well-Known Member
    1,521
    126
    Nov 30, 2012
    To review: It needs to be square with the direction of travel but can be rotated 90 degrees up. Also, it's basically a set it and forget it deal so having it in constant sight isn't that important. Can you fit it into your center console?
  3. xxxapache
    3,273
    1,247
    I wouldn't want a controller in my console. I want it within reach in case I need to manually apply the brakes to stop sway.
  4. tombiasi
    5,938
    1,490
    I have mine just to the right of the steering wheel. My knee doesn't go over that far and I can reach it. Each vehicle has its own challenge.
  5. Anthony Hitchings
    1,235
    573
    Mar 2, 2019
    needless to say, after posting my problem, and going back to the vehicle - it occurred to me to simply move it up a lot higher, to an area that seemed less likely but works in practice. Too bad about all the other holes in the dash from prior attempts :-(
    At least now I can get back to the wiring. Or I may abandon work for today as the garage is heating up, and does not have AC.
  6. dabsond
    dabsond Member
    43
    27
    Jul 17, 2015
    Dover, DE
    2011 Jeep Liberty owner here. Just so you know, my brake wire from rear 7 pin trailer connector was a red wire under the dash. I hear they may have changed the wiring harness a few times, different colors mentioned. The brake light wire from the pedal was the green and white striped wire.
  7. Anthony Hitchings
    1,235
    573
    Mar 2, 2019
    my jeep had no tow package so I recently installed a MOPAR electrical harness front to back, it had a blue wire for the brake (I removed my Curt electrical harness , it was only a 4-way connector)
    dabsond likes this.
  8. Tom Jordan
    Tom Jordan Active Member
    133
    85
    Jun 3, 2019
    ArkLaTex
    So, wanting to change my time-delay controller to a Primus IQ or similar, but I have limited leg room in my Nissan Frontier, similar to @Anthony Hitchings . Will the Primus IQ function correctly even when close to 90 deg. from horizontal? Picture shows my current time-delay that my uncalibrated eyeball puts at about 50 deg. from horizontal.
  9. Anthony Hitchings
    1,235
    573
    Mar 2, 2019
    according to the instructions, yes , it will function up to 90 degrees
    Tom Jordan likes this.
  10. Anthony Hitchings
    1,235
    573
    Mar 2, 2019
    so NOT solved - its a terrible location based on our recent trip. Back to the drawing board.
  11. Anthony Hitchings
    1,235
    573
    Mar 2, 2019
    This:
