Solving the "Dual Tank Auto Change Over w/HP Regulator" Problem
Discussion in 'Propane - Got Gas' started by kenquagliana, May 5, 2020.
  1. ezakoske
    ezakoske Active Member
    587
    100
    Nov 30, 2014
    Escondido, CA
    I expected the answer from Rego - from a safety and compliance standpoint, there is no way they would suggest anything other than the way the product was tested.
    Would the Rego option be cleaner? Yes.
    Have I ever had an issue with a tank running out and losing the use of my HP stove? No - not even on a week long trip.
    Spridle likes this.
  2. rabird
    7,255
    535
    N. TX
    In the good ole days Coleman used a 15 psi reg to feed the Coleman propane stove, it also feed a low pressure regulator for inside, code has changed requiring 2 stage reg with the first being 10 psi then 11". When Fleetwood stoped using Coleman propane stoves for outside then went with 16 psi for the HP stove
  3. Spridle
    Spridle Well-Known Member
    1,180
    379
    Jun 6, 2011
    http://www.regoproducts.com/lpgproductpdfs/7525b.pdf
    That's the valve in question. 15 psi at the first port. I also like the fact that it says it will pull gas from both in cold weather. Not sure how they pull that off, but I've been caught out in cold weather where the furnace would not start with just the one tank feeding it.
  4. rabird
    7,255
    535
    N. TX
    should work well
  5. Spridle
    1,180
    379
    Jun 6, 2011
    I don't see a check valve helping your cause. You need to just abandon that bypass or get a manual valve in there. The advantage to abandoning the bypass is it would reduce the number of fittings substantially.
    Or play with that Rago valve we just linked.
  6. kenquagliana
    kenquagliana Member
    89
    Nov 12, 2013
    Baltimore, MD
    Spridle, Your outside stove needs that 16psi HP regulator to function.
  7. kenquagliana
    kenquagliana Member
    89
    Nov 12, 2013
    Baltimore, MD
    Yes. It's looking that way. Thanks for everyone's input!!
  8. Sjm9911
    6,928
    4,316
    I know its not helping here, but i just take an extra tank along for the cooking. Easier to refill and less work.
  9. Spridle
    1,180
    379
    Jun 6, 2011
    Everyone just tell him to try that Rego! We need a guinea pig.
  10. mk4
    mk4 Member
    87
    65
    Nov 20, 2014
    Not an auto-changeover, but I'm replacing my dual stage with an adjustable 0-20 psi hp, then a tee to feed hp appliances and the lp regulator. Is this a horribly stupid thing to do?
  11. kenquagliana
    kenquagliana Member
    89
    Nov 12, 2013
    Baltimore, MD
    I spent my money!!! You need to spend yours!!! I built and installed my bypass with check valves ( at a lower cost). My furnace now works (due to bad LP regulator). I’ll be doing some tests tonight to see if two tanks with differing fill levels equalize with both tank valves open. That will tell the story. I believe if there’s any pressure differential at the check valves, they’ll favor the LP / Supply SIDE and allow the Primary to empty first. Obviously this is a bourbon and beer experiment. I’m still holding out hope. Keep us posted on the Rego solution. I’ll revert tomorrow.
    Ken
  12. Spridle
    1,180
    379
    Jun 6, 2011
    Certainly can work if you have a single state low pressure regulator. Not sure how it will like seeing 16PSI into a normal dual stage regulator though. What are you trying to solve?
  13. mk4
    mk4 Member
    87
    65
    Nov 20, 2014
    I wanted a hp port in addition to my lp port.
  14. mk4
    mk4 Member
    87
    65
    Nov 20, 2014
  15. Spridle
    1,180
    379
    Jun 6, 2011
    Do you have dual tanks or single? Regardless, this should work but typically the way the factory did it is to put a T before the regulators. One feed goes to the high pressure regulator, in your case the adjustable, and the other port to a typical dual stage low pressure regulator.
  16. rabird
    7,255
    535
    N. TX
    High Ken, with nothing operating the pressure in each container is the same based on temperature so both should feed your appliances. During use there may be a slight different temp in each container as one has more liquid than the other and the cooling as the liquid turns into gas may be different. I'm guessing there will not be much difference just using a stove or furnace, as one cylinder cools more and drops pressure the other will take over and vis versa. Have fun with this 'test'.
  17. rabird
    7,255
    535
    N. TX
    that's the typical Coleman setup before 2005 or so, a 16 psi reg, tee to outside hp stove, low pressure reg, at some pt they used dual reg to replace the single low pressure reg keeping the hp regulator. For a year or 2 viking used a 30 psi reg at the tank, teed to the outside and dual reg for inside.
  18. mpking
    mpking Well-Known Member
    1,427
    397
    Jun 17, 2014
    Raynham, MA
    Too bad there isn't a reliable gauge for Propane beside weight, or I'd suggest you put a pressure gauge in.
  19. kenquagliana
    kenquagliana Member
    89
    Nov 12, 2013
    Baltimore, MD
    Rabird,Thanks for your feedback!! That's good info. Test 1: Overnight, both tank valves open, no appliances running - I lost 1lb on the primary / supply side tank. The reserve tank remained unchanged. Maybe it took 1lb to pressurize the LP side from the primary tank. I don't have any leaks in the system (that I'm aware of). Next test: To run the HP stove for an hour and see if all the gas is pulled from the reserve tank as expected by design. Regards, Ken
  20. kenquagliana
    kenquagliana Member
    89
    Nov 12, 2013
    Baltimore, MD
    ......Correction.....Next test: To run the HP stove for an hour and see if gas is pulled from both tanks as expected, and see if they equalize. Regards, Ken
