Spray Lithium grease on roof suppport posts?
Discussion in 'Roof/Floor Repair & Maintenance' started by Fasttimes7, Sep 17, 2014.
  1. Fasttimes7
    Fasttimes7 Member
    115
    Sep 7, 2014
    Previous owner of my pup was using a can of spray lithium grease on the 4 roof support posts. The stuff is still on there and has gotten onto the canvas. Is this the correct stuff for this application? What should I use to clean off the grease on the canvas? Thanks.
  2. lugoismad
    lugoismad Active Member
    1,188
    Dec 31, 2013
    Not sure how to clean it, but you are supposed to use silicone lube.
  3. Milktrk
    Milktrk New Member
    331
    Apr 17, 2014
    ^^x2 make sure it's a dry silicone lube protecting the canvas from overspray.
    I would try dawn first that should do it- if you use anything stronger make sure you rinse it thoroughly.
  4. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    In my manual it says to use silicone spray on the pulleys and to make sure you use a shield to keep it from getting on the tenting. Really don't see the need for lubing where the PO did.
  5. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
    Looks like surface stain. Wet a washcloth with some mineral spirits (= paint thinner) to wipe it off. Too much mineral spirits will dissolve it and spread.
  6. kmh1596
    kmh1596 Wilbraham, MA
    5,362
    Aug 20, 2007
    Western MA
    I have an aggressive all purpose cleaner called "Blast" from a car detail supply place, that would work very well, just need to rinse well after. Will need to re scotch guard or the equivalent.
    Lesson learned of what not to use. Leave that on for a while And it will be black with dirt....
  7. Heritage
    Heritage New Member
    199
    Jul 6, 2013
    My pups previous owner did the same thing. That stuff is messy.
