Spring Over Axle Lift
Discussion in 'Tires / Brakes / Bearings / Axles' started by barrieb24, Mar 5, 2018.
  1. f5moab
    1,422
    472
    May 7, 2013
    Somewhere in Idaho
    Might be just a slight overkill for a popup; but if there were four I might be interested in lifting my GMC.[​IMG]
  2. f5moab
    1,422
    472
    May 7, 2013
    Somewhere in Idaho
    You're starting with smaller tires than I did. Mine came with ST175x80x13 (24" diameter), and I first went with ST205x75x14 (26" diameter). However, the ledges/rocks, etc., in SE UT tended to destroy the sidewalls of the ST tires and I really got tired of changing them and buying new tires. So when I replaced them I went with non-ST tires for a few reasons. Wanted a bit larger and a lot stronger, and a higher speed rating. So I went with Yokohama 215x70x15 (27" diameter).
  3. Katskamper
    Katskamper Well-Known Member
    833
    262
    Nov 21, 2015
    Fort Worth, TX
    everything is bolted here.
    the book shows both under - like mine & over.
    over makes it higher, allows for larger tire? right?
    not a job i want to DIY.
  4. jnc
    3,931
    1,192
    Oct 1, 2014
    South Central New Hampshire
    You are correct in that this is not a DIY job unless you can weld. To get bigger tires you need to move the axle under the springs.
  5. Brian Callicoat
    Brian Callicoat New Member
    Wednesday
    Hello. Where did you get the seats?
  6. Anthony Hitchings
    2,431
    1,356
    Mar 2, 2019
    Oakland, California
    the axle seats (perches) are available from etrailer and other sources
  7. Grandpa Don
    Grandpa Don Well-Known Member
    902
    617
    Sep 5, 2018
    I just completed the over/under conversion last week. I got all parts in a kit from etrailer. This weekend will be the first camping trip since the lift. Boondocking of course on some nasty forest roads. I even made and added a skid plate to the axle for more protections.
