Stabilizer dropping while driving
Discussion in 'Stabilizing Your Camper' started by Doyle, Jul 31, 2016.
  1. Doyle
    Doyle Member
    80
    Mar 30, 2014
    We packed up early this morning to continue on our journey. Stopped 90 minutes later for a kid pee break and coming back to the car noticed that the two stabilizers on passenger side had slipped down. The front one was about half way to the ground. The back one had been dragging on the road unfortunately and has damaged it fairly badly.
    It took all of my strength to raise it. Seems bent out of shape. Also, what was a circular stabilizer pad, is no longer circular. I know there's no real lock on these but really wasn't expecting these to slip down.
    This happen to anyone else out there?
  2. silvermickey2002
    4,778
    557
    Sep 11, 2008
    Morris County, NJ
    Not sure what type of stabs you have, but happened to one of ours a few years ago. Got out at the rest area and it was about half way down. Cranked it back up and realized that I had not cranked it up all they way to basically lock it in place by making sure it was cranked up tight. That was the only time that ever happened. I make sure when they are cranked up that I make sure they are tight.
  3. Doyle
    Doyle Member
    80
    Mar 30, 2014
    Yes exactly, I guess maybe they weren't tight up.
  4. tfischer
    tfischer Well-Known Member
    3,894
    1,343
    May 21, 2014
    You have to crank them up very tight. Our previous owner warned us about this and I've still had ours drop a little a few times.
  5. silvermickey2002
    4,778
    557
    Sep 11, 2008
    Morris County, NJ
    ^ What he said. Just make sure they are cranked up tight. It's amazing what a lot of vibration can do.
  6. tsc
    tsc Member
    813
    Aug 20, 2008
    SW Ontario, Canada
    Bummer.
    The "Sand pad" is easily replaced (the circular pad)--I quickly googled it and it was $28CDN on Amazon Canada for a 4 pack.
    If I remember correctly, they were an option or "add on"; so without it, you're not really missing much, unless you need to put the stabilizer on sand/loose surface. A 3" square piece of plywood would work too, just not as visually appealing.
    I personally have been very lucky and never had this happen. I tighten it til it's snug then 1/4 turn more.
    As to having it real hard to turn, try using white lithium grease and working it in. Hopefully it'll loosen up and be salvageable.
  7. ScoobyDoo
    ScoobyDoo New Member
    367
    Aug 23, 2016
    Don't have the screw type, and don't know for sure if it would be practical in this instance but for years if I had a screw that I did not want to jam tight, but did not want to loosen up, (let jack down) I would put a rubber washer, or rubber tube over the threads. Run up against the rubber, vibration is unlikely to cause it to turn...
  8. natty bumppo
    natty bumppo 2009 F-150,1998 Coleman Westlake
    436
    Jun 22, 2008
    Pilot Moutain,NC
    Zip ties!
  9. nineoaks2004
    8,046
    3,588
    Dukes, Fl
    a small bungee will work too, I once had one (not the screw type) that would not lock in the up position so I used a bungee to keep it up. Since going dark I have the screw type and as stated they must be screwed up tightly when in the position for travel.
  10. tzmartin
    tzmartin Well-Known Member
    1,128
    525
    Sep 9, 2015
    Interesting that the road ground down the sand pad so evenly. Imagine the shower of sparks at night!
    You also might need to realign the stab by wacking it gently with a hammer. The road may have bent the mechanism a little.
