stabilizer/leveler broke
Discussion in 'Stabilizing Your Camper' started by sonoma camper, May 22, 2012.
  1. sonoma camper
    sonoma camper New Member
    45
    Jul 21, 2009
    Sonoma County, Ca.
    I have a 1995 Coleman/Fleetwood Sequoia modelcamper. When I was leveling the camper the right rear stabilizer broke. I might have gone too far with it. It was prettymuch verticle when it broke. There is a pin with flatened ends on each side of the "foot" piece. It seems to have pulled the foot piece out from the pins. The holes are now out of round because the the pins pulling through. I'm not sure how it can be fixed (if it can)? A new one would be pretty expensive I think. Maybe have the holes welded and redrilled? If I do this, those flattened pins won't go through (because the pin ends a larger than the holes) so I'm a bit in the dark here. Anyone with a similar model will know what what I mean. Any suggestions will be appreciated. If all else fails, where can I get another?
    The stabilizers have a long screw bar that is cranked up or down depending on if you are cranking up or retracting the foot.
  2. teejaywhy
    teejaywhy Active Member
    1,411
    Jul 19, 2011
    I can't offer any advice about fixing it but for future reference, it is not recommended to use the stabilizers for leveling.
  3. Flyfisherman
    Flyfisherman New Member
    3,682
    Mar 4, 2003
    Shallotte, North Carolina
  4. Starcraft Away
    Starcraft Away New Member
    853
    Feb 10, 2012
    I second this peice of advice, they are meant to steady the Pup only.... not meant to lift it off the ground.
  5. sonoma camper
    45
    Jul 21, 2009
    Sonoma County, Ca.
  6. sonoma camper
    45
    Jul 21, 2009
    Sonoma County, Ca.
    Well, I use it to stabilize and by cranking one a little more or less you get it level. This is what the guy I bought it from told me. It has bubble levels in the corner on inside. One for lenght & one for width. I never use them to raise it off the ground. How else would you level it? 4 separate jacks? I guess you wouldn't have to level it if you camped on asphalt type camping grounds, but I usually don't camp that way. Usually on dirt and it needs leveling.
  7. papachaz
    papachaz New Member
    2,821
    Jun 26, 2011
    absolutely going to agree with the others. those are to STABILIZE the pup only. they are not meant to be used to level the camper.
    i'll suggest canvasreplacements.com or bear creek canvas. they have parts. good luck!
  8. jenoble99
    jenoble99 New Member
    379
    Jul 3, 2008
    Indiana
    You back the low side wheels up on pieces of wood, on lynx blocks, or a BAL lever. That is the proper way to level.
  9. rabird
    7,239
    526
    N. TX
  10. teejaywhy
    1,411
    Jul 19, 2011
  11. sonoma camper
    45
    Jul 21, 2009
    Sonoma County, Ca.
    yes. just the piecr the foot pad is on.
    Thanks guys for all your input!!
  12. sonoma camper
    45
    Jul 21, 2009
    Sonoma County, Ca.
    Yes this is exactly it! thanks. Might just buy a new one instead of trying to fix mine. $60 for two + shipping is not bad
  13. Dusty82
    Dusty82 Active Member
    3,513
    Jun 23, 2008
    Northern Nevada
    Good luck with the replacement.
    As has been said, don't level the pup with those stabilizer jacks. You're right - that's why it broke. It also puts just enough twist in the frame to put the lift system in a bind, it can make the bunks harder to push in and pull out, and can make the door not fit or close right - among other problems. Level from side to side with something under the low side tire or a BAL lift, and level front to rear with the tongue jack. Also, on a Coleman/Fleetwood pup, raise the roof BEFORE you put the stabilizers down to keep the lift system from binding up. Put the stabilizers back up before you crank the roof back down for the same reason.
    The stabilizer jacks are there to do just that - stabilize the pup while you move around inside it. They should be snugged down to the ground just enough to keep the trailer from rocking and rolling while you're inside it. I know all of this because I did the very same thing, and fought a host of other problems that were caused by trying to level the trailer with the stabs.
    Good luck!
  14. Hawkester
    Hawkester Hawkesnest
    1,337
    28
    May 23, 2008
    SE Wisconsin
    To bad your not in Wisconsin. I have 1 broke stabilizer and haven't bought one because it's the one closest to the tongue jack. Trailer still stabilizes fine but it would be nice to have 4 again, just can't bring myself to buy two.
  15. sg1215
    sg1215 my God, my Country, my Family, my Friends, myself
    151
    Jan 13, 2010
  16. cwolfman13
    cwolfman13 Active Member
    3,218
    Feb 9, 2011
    X2.....Had the same thoughts initially...thought the stabs were to level. Had a bear of a time the first time trying to do it, so thought something I was doing must be wrong. I actually talked to another buddy of mine (didn't think to get on the portal at the time) who has a p'up and he had a good chuckle and told me I was going to break something.....either on the p'up or a limb. He brought his BAL Leveler over; soon after I became a proud owner of a BAL Leveler. Lynx Blocks or wood scraps are your less spendy alternatives. Had I read my owners manual carefully, I would not have made this error to begin with, but in my case; no harm no foul. I too am generally camped out in the boonies and I've had my BAL Leveler at max to level side to side.
  17. sonoma camper
    45
    Jul 21, 2009
    Sonoma County, Ca.
  18. sonoma camper
    45
    Jul 21, 2009
    Sonoma County, Ca.
    thanks to everyone for their imput. I will level it properly from now on! I think I repaired my stab. I'll put it back on and try it. If I don't think it will hold I'll buy a set. I wonder why they don't sell just one? This forum is the best!
