Stabilizer pads
Discussion in 'Stabilizing Your Camper' started by Heelbilly, Jan 26, 2021.
  1. Heelbilly
    Heelbilly New Member
    Oct 1, 2020
    What, if anything do most use as a pad under the stabilizer jacks? If you use something, about how is it?
  2. tombiasi
    6,639
    2,209
    When I need them its a square piece of 2x8.
    UpNorth-John, Sjm9911 and Ladiesman like this.
  3. Annunzi
    Annunzi Active Member
    175
    149
    Jun 14, 2019
    Vancouver Island, British Columbia
    I use the yellow Camco levelling blocks, I like them because they are easy to stack/store
    Indiobravo, Sjm9911 and gladecreekwy like this.
  4. JimmyM
    JimmyM Well-Known Member Gold Supporting Member
    3,136
    1,121
    Jun 5, 2014
    Franklin, MA
    I use Lynx levelers. I've used 2x8s/2x12s as well. Both work great. Lynx levelers are lighter, 2x8s are cheaper.
  5. Dingit
    Dingit Well-Known Member
    1,786
    1,265
    Mar 8, 2017
    We use Lynx levelers. Or Camco. I forgot which. They're kinda the same. We have "sand pads" on our stabilizers so only need them when the terrain makes our stabilizers too short. (We have a flipped axle so this happens more often than it otherwise would.)
    PopUpSteve likes this.
  6. Ladiesman
    Ladiesman Well-Known Member
    755
    541
    Feb 6, 2018
    I use wood, I made little handles with some straps and screwed them on to the ends. It just makes them easier for me to carry and to pull out and pick up.
    Camperboy#13 and Sjm9911 like this.
  7. kitphantom
    13,218
    2,325
    We use Lynx Leveler blocks with caps. We have had sand pads on the stabs on both our second popup and current small TT, but the Lynx blocks are still helpful. We often use anywhere from 1-5 of them in a stack. Both the pup and TT have been somewhat raised, so not extending the stabs to close to max is more stable. The blocks are also good on softer surfaces, even sand pads can begin to sag into soft ground.
  8. PopUpSteve
    PopUpSteve Administrator
    20,010
    2,932
    Dec 22, 2002
    Malvern, PA
  9. Sneezer
    2,856
    1,690
    I use Lynx levelers with caps. I also have a set of some other brand I got at a garage sale that I like better - the lego blocks are closer and more numerous, negating the need for a cap with my pads. So far I have not needed any more than the 2 bags to cover the 4 stabs and the trailer tongue jack. I use a BAL for side to side on the wheel.
  10. Heelbilly
    Oct 1, 2020
    Thanks all. I’ll look into the plastic pads
  11. Dingit
    1,786
    1,265
    Mar 8, 2017
    Wood is totally fine if you don't need the extra height. (I only use the plastic ones because I had them already.)
  12. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    Ikea Bed Lifts (or equal) - which also nest to take up less space when not in use. They work great for our ALiner.
  13. nhcaveman
    nhcaveman Barrington, NH
    1,332
    86
    Mar 25, 2009
    New Hampshire
    Steve,
    I'm curious, why do you say don't stack the Lynx Levelers?
    I generally stack them 3 or 4 high because I feel the less you extend your stabilizers the less movement you'll have.
    Am I wrong with this way of thinking?
    kitphantom likes this.
  14. PopUpSteve
    20,010
    2,932
    Dec 22, 2002
    Malvern, PA
    Personal preference. I've had the tongue jack almost slip off a stack when on a slop.
    I use a flat foot-pad on the tongue instead of a wheel. I wish Lynx Levelers made a pad with an indent. I've thought about using a dremel to cut one of my Lynx blocks so the flat foot-pad of the tongue would fit. If they just made the Lynx Flat block with a lip.
  15. BikeNFish
    BikeNFish Well-Known Member
    4,138
    3,121
    Apr 24, 2017
    Maplewood, MN
    I use one foot lengths of 2x4's. Only because that is what I had on hand when I made them.
    It is my thought that anything wider than the stabilizer base could work because their purpose is to increase the footprint of the stabilizers, especially on soft ground. The softer the ground, the wider the pad.
  16. WrkrBee
    WrkrBee Un-Supported Member
    6,539
    3,448
  17. Dingit
    1,786
    1,265
    Mar 8, 2017
    if it keeps you out of the firepit...
  18. PopUpSteve
    20,010
    2,932
    Dec 22, 2002
    Malvern, PA
  19. WrkrBee
    6,539
    3,448
  20. cyclop5
    cyclop5 Active Member Silver Supporting Member
    163
    78
    Jun 18, 2015
    I have a couple 1ftx1ft pieces of plywood I use. small enough for storage, wide enough to stabilize in sand/soft dirt. Also, I don't need to be "exact" when I place them. Also, it's what I had handy when I realized I needed something :)
