Stabilizer pads
Discussion in 'Stabilizing Your Camper' started by Heelbilly, Jan 26, 2021.
  1. nhcaveman
    nhcaveman Barrington, NH
    1,332
    86
    Mar 25, 2009
    New Hampshire
    I could probably take a a Lynx Cap and mill the pocket into for you. If you'd like, measure that foot pad and let me know what size it is. I'll mill it about 1/8" deep, that's just deep enough that the pad won't pop out with pressure on it, but not so deep as to effect the structural strength of the Lynx Cap.
  2. Sjm9911
    10,614
    7,996
    I have a aluminum jack stand sort of that the tube goes into for the toung jack. Adds height and has a decent base. It is bigger then a lynex leveler. It is pretty secure without adding anything else under it. Way bigger foot print then the smaller flat one.
  3. PopUpSteve
    PopUpSteve Administrator
    20,000
    2,910
    Dec 22, 2002
    Malvern, PA
    Thanks. Let me find out how thick the pad is and if it milled out. After think about this over the last few days, perhaps a better way to do this would be to put blocks on the top of the Lynx Cap to prevent the slippage of the stabilizer/tongue pad.
  4. Snow
    11,799
    2,377
    They do.. the chock r' dock ...
    https://trilynx.com/collections/tri-lynx-products/products/lynx-chock-r-dock?variant=31841396785194
    kitphantom likes this.
  5. xxxapache
    4,088
    2,368
    My stabs have 4" round pads on them. I rarely use anything under them. I do keep a few lengths of 5/4" decking board and 2 x 6 in the TT in case I need them, though.
  6. Snow
    11,799
    2,377
    So do mine and I always use at least 1 Lynx Leveler under them and had as many as 10 ..
  7. xxxapache
    4,088
    2,368
    Is your trailer riding on leaf spring axles? Leaf spring trailers seem to sit much higher than my torsion axle TT. I often seen leaf spring trailers with 6" or more of blocking under the stabs.
  8. kitphantom
    13,206
    2,309
    For us, we had a higher popup (Coleman Cobalt) and our TT is raised a bit (4-5") from the the too-low level as it was originally designed. We use 5 blocks+ cap under the tongue jack, less cranking for us,and the jack isn't extended to the max that way. (We did not replace the tongue jack when the second lift was added). Depending on the slop of the land, we use 1-5 under each stab. Unless it's really hard pack or concrete, we use one block/cap under stabs, just to spread out the weight; it seems to help. We've encountered a couple of places with asphalt that required the big RVs to use pads, so we figure it's good for us too. In our sloped driveway, we use 5 under the downhill stabs, just 1-2 under the uphill ones (depends on just where the trailer is parked, since the dirt next to the driveway is almost a block depth lower than the concrete.)
  9. PopUpSteve
    20,000
    2,910
    Dec 22, 2002
    Malvern, PA
    That's for a WHEEL on the tongue jack, not a pad.
  10. Sjm9911
    10,614
    7,996
    Never had a problem with it, it only has wood under it so it dosen't sink in the asphalt.
    hardheadedwoman and sherpa like this.
  11. Sjm9911
    10,614
    7,996
    And for the life of me i can not find another one like it. It was given to me and is aluminum. I see plastic ones but not aluminum.
    hardheadedwoman likes this.
  12. Sneezer
    2,856
    1,689
    My pup has a torsion axle, on the one hand it is lower profile, and easier to step into. Sometimes my step isn't even needed. On the other hand, if the site has a bad enough slope you can't lower the rear stabs since they swing down and out. I rarely use more than one bag of Lynx, but they do some in handy for leveling the camp kitchen too.
  13. xxxapache
    4,088
    2,368
    My stabs just crank down. When up, they higher than the lowest point on the belly.
  14. Sneezer
    2,856
    1,689
    Yeah, I wish I had those. Mine are the folding kind that pull out, swing down and use a ratchet mechanism to snug them up.
    Similar to this:
  15. Snow
    11,799
    2,377
    Remove the pad the post will then sit in the groove.. or use a 6x6x6 wood block with the pad..
  16. Snow
    11,799
    2,377
    Yes has lead spring but drop spindles on it, I only have about 8 inches of ground clearance under the spring perches.. and axles sit on top of the springs.
  17. sherpa
    sherpa New Member
    22
    Mar 1, 2018
    I cut up a pressure treated 2x8 i had into 5 pads: one for each corner and one to go under a donut chock under the front wheel. I use them all the time to distribute the pressure on the ground. I'm never on pavement or rock and I figure it will compress less.
    They weigh a bit, but are cheap. After looking at answers here I may be attaching a rope loop to make handling easier.
  18. RichRL
    RichRL New Member
    Dec 2, 2019
    Northwest PA
    We have used plastic cutting boards from Walmart with good success and the price was right.
    xxxapache likes this.
  19. Ed Betty
    Ed Betty New Member
    Oct 12, 2020
    2X6X8, when camping in a non park situation they cover many issues that make setup more secure (sand, holes, not level terrain). Cheap and easily replaced,
    n
  20. MileHigh
    MileHigh Active Member
    500
    116
    Jul 18, 2012
    Denver
    2 x 8's cut into squares. I keep 6-8 of them and could always burn them if I needed to.
