"Stabilizer Support" needed!
Discussion in 'Miscellaneous Repairs & Maintenance' started by taztig, Oct 10, 2019.
  1. taztig
    taztig New Member
    Dec 2, 2012
    Fh, Az.
    Help !!
    I am having difficulties locating the manufacturer and model of the stabilizing/leveling jacks that are used on my 2008 Starcraft Centennial 3612!
    It does have the 3/4" hex drive shaft to raise and lower the leg support.
    One got damaged and I would like a matched replacement.
  2. WVhillbilly
    WVhillbilly Well-Known Member
    649
    443
    Jun 6, 2018
    WV
    Have a picture?
    Many of these jacks are pretty standard and it shouldn't be hard to find a replacement.
  3. GreyFox
    GreyFox Well-Known Member
    1,311
    593
    Oct 10, 2018
    S Ontario
    Most popups with crank style stabilizers use those manufactured by Norco under their BAL product line.
    https://www.amazon.com/BAL-23225-Se...+jacks+for+tent+trailer&qid=1570706780&sr=8-6
    Note that these are stabilizers and are not intended to ever be used to level the trailer, as in never.
    Snow likes this.
  4. PopUpSteve
    PopUpSteve Administrator
    18,809
    1,580
    Dec 22, 2002
    Malvern, PA
    Just "Stabilizing"! The quicker you think of them only for that use, the better for your camper. [:D]
    As above, a photo would help but from your description, they do sound like the type @GreyFox posted about.
  5. Camper054
    Camper054 Active Member
    113
    46
    Jul 23, 2019
    I am the same - meaning one of my four stabilizing jacks is also hard to lower. There is a washer I have to hold with one hand while turning the crank handle. So, I am thinking that I may have to replace it at some point. Can I not use one of the regular jacks like you can find at HF?
    Something like: https://www.harborfreight.com/3-ton-steel-jack-stands-61196.html
    Anything wrong in using them if needed?
    Thanks
    MC
  6. WVhillbilly
    649
    443
    Jun 6, 2018
    WV
    bheff likes this.
  7. bheff
    bheff Well-Known Member
    723
    315
    Feb 24, 2011
    NW Arkansas
  8. Camper054
    113
    46
    Jul 23, 2019
    @WVhillbilly , @bheff , yes, I think the scissor jack would be a better choice :). Thanks!
  9. GreyFox
    1,311
    593
    Oct 10, 2018
    S Ontario
    WAY overkill for a popup.
  10. WVhillbilly
    649
    443
    Jun 6, 2018
    WV
    Camper054 likes this.
  11. taztig
    taztig New Member
    Dec 2, 2012
    Fh, Az.
  12. taztig
    taztig New Member
    Dec 2, 2012
    Fh, Az.
    That is exactly I need what I am looking for thank you!
    Now my only other concern would be the bolt pattern measurements, do you think those would be pretty much universal or I may have to drill new holes to attach to bottom of pup?
