Stabilizing when on a hill
Discussion in 'Stabilizing Your Camper' started by virtualjeff, Jul 19, 2020.
  1. virtualjeff
    virtualjeff New Member
    26
    Sep 15, 2015
    San Diego, CA
    What do y’all do when your campsite is on a hill and you’re not able to put the front or rear stabilizers down? This has happened a few times in the past and it gets wobbly.
  2. Aladin Sane
    1,145
    170
    Jul 3, 2008
    Iowa
    I use wood cribbing. Build up a base to extend your stabilizers to.
    Tom Jordan likes this.
  3. virtualjeff
    26
    Sep 15, 2015
    San Diego, CA
    I carry boards if they’re not long enough. Sometimes, there’s a hill where I can’t physically lower them, because I don’t have enough clearance. Not sure what to do in that scenario.
  4. WrkrBee
    WrkrBee Un-Supported Member
    6,538
    3,448
    You can dig out for the stabilizer or use a small jack and set the corner down on cribbing.
    virtualjeff likes this.
  5. kitphantom
    13,216
    2,323
    This is the reason we carry 4 sets of Lynx blocks and caps, for leveling and under the stabs. We use a stack of 5 blocks under the tongue jack with our current set-up, since the trailer has had a lift. We often use a block and cap, no matter the slope, under the stabs (which do have the round sand pads) tend to sink less.
    This is the site that made us realize we needed more Lynx than we had at the time
  6. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    use Ikea bed lifts, cheap, tall, and they nest for stowing
  7. virtualjeff
    26
    Sep 15, 2015
    San Diego, CA
    Thanks! I’ll look into both!
  8. Snow
    11,800
    2,380
    X2 on the Lynx Levelers but I have about 8 bags plus a few caps. Last year was on a site that required a full bag of blocks under each front stab, also had to use some under the tongue jack and had to make an extra step to get in/out of the trailer.
    virtualjeff and kitphantom like this.
  9. virtualjeff
    26
    Sep 15, 2015
    San Diego, CA
    How do you guys use the Lynx blocks if you can’t pull down the stabilizers it on a hill? Or do you use the blocks to jack up the trailer to get more height? I use a BAL leveler one side and chock on the other.
  10. kitphantom
    13,216
    2,323
    We have stuck with Lynx blocks for leveling, and use the Lynx chock on that side; BAL chock on the other. Have never had a site where we couldn’t use the stabilizers. (With the tiny/low to the ground first popup, we had no stabs on it, and it was challenging at times to place the stack jacks, but at least they were moveable)
  11. nineoaks2004
    8,244
    3,715
    Dukes, Fl
    I either save 2' scraps of 6X6 or 4X4 that I cut off from fence posts or other projects here on the farm. Price is right for me.
  12. virtualjeff
    26
    Sep 15, 2015
    San Diego, CA
    It happened once last year at Sequoia. It sucked lol. I have a jack from my car that I could use might pick up another one for the other side.
  13. Snow
    11,800
    2,380
    Our TT has crank down stabs, so always have had the ability to crank them down. Least amount of cranking so far has been about 2 inches on the rear stabs... that was last year when I used a full bag under each front stab..
  14. jmkay1
    6,968
    4,014
    My last popup had fold down stabilizers. If I found myself on a hill that I couldn’t fold down the stabilizer I put lynx block under my tires. Then lowered the high side enough to raise the side I had trouble lowering the stabilizer On until I got it out then re leveled. Most of the time I was only off by a little bit and once in its position i was able to level like normal without a problem. You just have to remember to reverse that process when closing up. One of the reasons I really love the Crank stabilizers on my new to me popup.
  15. Aladin Sane
    1,145
    170
    Jul 3, 2008
    Iowa
    Yes, crank stabilizers are better than fold down in every way.
  16. virtualjeff
    26
    Sep 15, 2015
    San Diego, CA
    @jmkay1 that makes sense, thanks! I'll pick some up.
