Stand alone 12v converter
Discussion in 'Wiring' started by Matt Benoit, Aug 22, 2017.
  1. Matt Benoit
    Matt Benoit Well-Known Member
    544
    336
    Jul 30, 2017
    Warren, MI
    Hey guys! Our new too us pup is coming along with mods and upgrades, but I've noticed something i wanted some advice on. The 12v power converter in the pup must have died long ago, and since the only thing running on 12v is 2 led lights (one overhead inside and a porch light outside), the previous owner decided to separate the 120v from the 12v, and bought an inexpensive 12v converter that plugs into a wall outlet on the dinette. It creates 12v @4A, and is tied directly into the circuits for the 2 lights. As far as i know, its been like this for awhile, and we've used the pup a few times without issue. My question is, should i leave it alone? Or should I replace/upgrade the main power center? The pup has no battery, no heater, no water pump, And we only camp where shore power is available...so is it really worth it to replace the converter? Thank you for your opinions.
  2. NMroamer
    NMroamer Well-Known Member
    865
    591
    Apr 21, 2016
    Albuquerque NM
    If this works for you and is not broke do not fix it.
    Matt Benoit likes this.
  3. Antipodes
    Antipodes Call me Paul
    772
    76
    Jan 28, 2015
    Christchurch, New Zealand
    Agreed!
  4. Customer
    Customer Well-Known Member
    2,435
    249
    Jun 5, 2014
    Probably fine but the brand and model of converter would be helpful. I can't see it from here. [:D]
  5. arthuruscg
    arthuruscg Active Member
    1,363
    Nov 14, 2012
    How do you switch to battery power when you don't have 120V available?
  6. Matt Benoit
    544
    336
    Jul 30, 2017
    Warren, MI
    There is no battery. So no option to switch to battery power lol. We only camp where shore power is available... Typically 30a sites as we use ac alot
  7. roybraddy
    roybraddy Well-Known Member
    2,394
    947
    Mar 23, 2016
    King George, Virginia
    I use the BLUE SEA 12VDC switches shown in this battery layout... In my case i have to have my batteries switched on-line to provide 12V DC power as required by DOT to operate my trailer Electric Brakes in the event the trailer becomes disconnected from the the truck when being pulled on the the State Public Roadways...
    Roy's image
    My PD9260C Converter unit is stand alone mounted between the Power Distribution Panel where all of the 120VAc Circuit breakers and 12VDC Fuses positions are located as close to the main battery switch as i can get it and still be inside my OFF-ROAD Popup Trailer. All 12VDC primary cabling is 4AWG size using standard crimp-on ring terminal ends...Both the 12VDC Switched battery cables and the 12VDC DC outputs from the Converter unit feed the same point on the Power Distribution Center unit. This allows my OFF-ROAD Camper Trailer to operate from both 120VAC Shore Power connections and the 12VDC Battery bank setup.
    Google Image
    Typical 120VAC and 12VDC 30A Power Configuration for 30A RV Trailers...
    Google Image
    Roy Ken
