Starcraft lift system
Discussion in 'Lift Systems' started by cwilems1, Mar 23, 2019.
  1. cwilems1
    cwilems1 New Member
    Mar 23, 2019
    Does anyone know what type of lift system the 2010 Starcraft 1224 model has? We recently bought ours used and a cable is broken (we think). We’d like to try to fix it ourselves if possible to save money, but we can’t find much about the camper online. We had to get the owners manual Fromm starcraft, but it looks to be a general manual for all models made that year and not specific to the 1224. Can anyone help?!
  2. GreyFox
    GreyFox Well-Known Member
    2,447
    1,275
    Oct 10, 2018
    S Ontario
  3. J Starsky
    J Starsky Well-Known Member
    967
    822
    Aug 3, 2017
    East Central MN
    I found PDF manuals for my 1984 by emailing Starcraft. They may have a few models but with some diagrams you'll see how the lift should operate. Make 2x4 supports for each corner. You'll need to get it up to work on it. Safety 3rd at least !!
  4. cokes17
    cokes17 New Member
    Apr 5, 2018
    Summit County, CO
    Starcraft is owned by Jayco and have supposedly used the same lift system since '68. I have the same model but fortunately haven't had to dig into it too deep, but this document is really good. Good luck!
    http://nissanpatrol.com.au/Jayco-Book2-k8g7.pdf
    popupparts.com seems good too
  5. 1380ken
    1380ken Well-Known Member
    2,594
    1,003
    Nov 7, 2013
    Mass
    If it is the Goshen system like my 1997 Starcraft, then the broken cable is very easy to change. The cable is changed from underneath with the top down.
  6. Dan from Troup
    810
    502
    Apr 25, 2018
    Troup, Texas
    Replaced my lift cable on my 06 Starcraft and yes, it is the Goshen system. I ordered mine directly from them. http://goshenstamping.com/
    Garrity and J Starsky like this.
  7. Huskywalker
    Huskywalker New Member
    May 26, 2019
    Raleigh, NC
    I want to piggyback on to this post. I am new to pop up camping. I have a 2002Starcraft. I read 2 manuals listed here regarding the lift system. I am somewhat mechanically inclined but getting that much into the lift system is more than I want to deal with especially since I would be working on the street. My popup’s symptoms are: I am unable to pop the door in place, the back of the camper is about 1 inch lower than the front, the Velcro cover that goes over the roof supports, on the door side of the camper does not go in a straight line and will not allow the Velcro to attach. See pictures attached. Are these symptoms a small adjustment needed from the outside of the pop up or possibly a larger problem that requires looking under the floor by a mechanic? If I need a mechanic to look at it in the floor what is realistic price range I can expect?
    Thank you
  8. davekro
    davekro Active Member Gold Supporting Member
    685
    260
    Aug 30, 2019
    SF Bay Area, CA
    For Older Starcraft's 1985 to 2000 (maybe to 2005?), they used the Shelby 5438 lift system. I'll plunk this info here in case those owners/users find this thread in their searching. If you still can't recognize your system, search this site for 'Goshen' and 'Shelby 5438' to find more info, rebuilds, etc.
    1990-2000 Starcraft liftsystem Shelby 5438
    https://www.popupportal.com/threads/1990-2000-starcraft-liftsystem-shelby-5438.119981/#post-1222747
    99 Starcraft Spacemaster - Shelby Winch questions
    https://www.popupportal.com/threads...r-shelby-winch-questions.112199/#post-1306721
    Link to a PDF of the Shelby 5438 Lift System (1985 - 2000 (+?), + most 83 & 84's)
    Note: when this link opens, go to your downloads folder to find the PDF doc.
    https://rvworkshop.com/sc_images/Starcraft_1985___Newer.pdf
  9. BillyMc
    BillyMc Well-Known Member
    2,003
    1,343
    Mar 25, 2018
    Was it like this when you bought it or is this something that is a recent issue?
  10. Huskywalker
    May 26, 2019
    Raleigh, NC
    It was not like this when I got it. I took it on a 3700 mile journey this summer. The last place we camped I noticed the screws at the top of the front lift support were loose and the support moved. I tightened down the screws on the front and the back on the door side of the pop up. The other side was fine. At this camp site, we also missed the back right corner when we unlatched the roof. I started to raise the roof before I realized it. I have been very cautious not to force anything on the pop up. If it gets difficult I stop and check.
    Thank you
  11. davekro
    685
    260
    Aug 30, 2019
    SF Bay Area, CA
    Do you know what lift system that you have (Goshen, Shelby 5438, other)? If not, look under the floor/frame and snap a picture of the winch assy, or lift mechanism. See links in post # 8 above for what the Shelby 5438 system looks like (on my '99 10' box Starcraft Stardust). What model and box size is yours. My '99s lift struts are SS and wider than yours. I have not seen those before.
  12. Huskywalker
    May 26, 2019
    Raleigh, NC
    I have the 2002 Starcraft M1701, 10 foot box. I Sen an email to Starcraft to see what lift system I had, they have not given me any answer yet. Said they needed to research it... I believe I have a Goshen, but not sure. The winch is at the front of the camper on the towing tongue. I am attaching pictures. If this isn’t what you were looking for let me know.
  13. davekro
    685
    260
    Aug 30, 2019
    SF Bay Area, CA
    Someone will likely recognize this system. I have a Shelby 5438. Yours is not a Shelby, which I believe you knew anyway, so I am of no help. But your pictures will help in answering your question. For others who are not sure what lift system they have, my 99's Shelby 5438 system crank is at the curb side rear side. It is unique because it has a male 'OVAL' shaft requiring a female oval end on the crank handle. https://www.larrycloth.com/tent-crank-and-camper-handle-pop-replacement-up-starcraft-older-1994 I just ordered this $14 (+ $4.50 shp) handle, so I could cut off the end and use it on a cordless drill to raise my 10' box's roof. :)
  14. davekro
    685
    260
    Aug 30, 2019
    SF Bay Area, CA
    DO NOT BUY FROM LarryCloth.com, It is a sham. $18 lesson that I may be able to recover from PayPal, but still. cost me 2 months 'waiting' for a package from China. A package arrived yesterday. A pair of socks. Well I learned my lesson on saving a few bucks. Off to buy the recommended oval socket adapter from RV Workshop. https://www.rvworkshop.com/socket-jenie/lvsg-406
    PointyCamper likes this.
  15. djsciz
    djsciz New Member
    Dec 9, 2020
    Louisiana
    I need to know this as well, and nobody answered the OP's question. I don't think its Goshen. Their website clearly states they manufactured lift systems for Starcraft from 1993-2008.
    I see absolutely no lift equipment under the camper. The crank is located at the rear, passenger side.
  16. J Starsky
    967
    822
    Aug 3, 2017
    East Central MN
    If you have a StarCraft, email them. They had manual for my 1984. That included blow outs and diagrams. They built it and know it best.
    Good news, I repaired my old gal well before the interwebs made popups and manuals popular. You can fix it if you want to do it and have a little mechanical sympathy. Good Luck!
  17. 1380ken
    2,594
    1,003
    Nov 7, 2013
    Mass
    Your lift system in not a Goshen. You would see the whole lift system under the camper.
  18. BillyMc
    2,003
    1,343
    Mar 25, 2018
    First question
    Does the crank use a small oval or a fairly large square drive?
