Starcraft roof lift winch system question.
Discussion in 'Lift Systems' started by Fe4life, Jun 13, 2010.
  1. Alli
    Alli New Member
    29
    Aug 3, 2017
    Yours is a different mechanism than ours, but maybe something will help. When I popped the pup up and got it "stuck" it was a rod down by the metal cable. When it's fully raised and cable is taught the "rod" catches and acts like a safety "brake." When that piece "catches" into place you are STUCK until you release the piece to drop the top. I get that my explanation is rough, but this pop up lifestyle is new.
    Look at pic. You see the metal cable. Under that is the black rod that I was referring to. As the roof is raised that rod moved toward the metal. The rod is about as big as a straw and the end hooks onto the metal. I raised it too high/ overextended and that's where issue happened. The rod hooked over the metal. You can see the ground/opening.
    The pic is from when the roof was stuck in "up" position. Once the hubs and I figured out what was going on and why it's been very easy to navigate. I can drop it down all by myself in about 15 min.
  2. Chido
    Chido New Member
    Aug 1, 2018
    Does anybody knows where I can order a winch sistem like this?
  3. SpacepiG
    SpacepiG New Member
    Jul 25, 2018
    Detroit area, Michigan
    You can not as they went out of business 15 years ago. I found one used system online for $650!!! It is a shelby 5438.
    What is the problem? I restored mine for approximately $30 and if you can describe the issue i can tell you how to fix it, i have taken it apart many times. See my post for starcraft liftsystem.
  4. Chido
    Chido New Member
    Aug 1, 2018
    The threads on the gear are gone, also the threads on the shaft are damage 20180801_155937.jpg 20180801_155954.jpg 20180801_155954.jpg
  5. SpacepiG
    SpacepiG New Member
    Jul 25, 2018
    250C9DF3-CBBC-4244-9CB4-46D17B6872BC.jpeg I had same issue. I milled out an area in the middle, welded it, drilled it and threaded it with left hand 5/8-11 and re threaded the shaft as well.
    If you or your work do not have the tools then go to a machine shop/tractor tepair and they should be able to do it for $40-$50
  6. ManiN
    ManiN Member
    50
    Jun 10, 2014
    Was having issues on my Shelby where it got stuck trying to lower the top that was sitting up for 3 weeks. It ended up coming loose with just a slight turn on the cable drum which seemed hung up for some reason. All's well now with some lube.
    Curious though, I was worried it may be having thread issues such as shown in your pics. How did this happen? Did someone over crank it? Was it jammed and someone tried to just keep cranking through the resistance? I'd like to avoid this stripping the threads out on the gear if I can help it.
  7. Chris Pittarelli
    Chris Pittarelli New Member
    Feb 21, 2020
    this is a complete shot in the dark, but to you have the diagram still for the lifting system? I have to replace a broken cable
  8. tfischer
    tfischer Well-Known Member
    3,811
    1,255
    May 21, 2014
    Fe4life was last seen here in 2011. Indeed a long shot.
  9. Chris Pittarelli
    Feb 21, 2020
    Lol, I figured as much, actually figured out how to get the broken wire out, just having trouble locating a replacement
  10. Adam B Ugorowski
    Adam B Ugorowski New Member
    Apr 21, 2020
    Hey how did you get your cables removed from the large cylinder terminal with the gear on the right side, with the hole the cable were in? I'm replacing one of those cables that leads into the largest tubular cylinder with the gear on side, but I don't know how to open it up. Does any one know I've looked on the internet for hour on hours about how to open this, if anyone knows it would be a tremendous help!
  11. WrkrBee
    WrkrBee Well-Known Member
    3,601
    1,540
    A picture would help us understand what you are calling what. Welcome to the Portal from South Carolina.
  12. Adam B Ugorowski
    Apr 21, 2020
    The red arrow is pointing to the cylinder where the cables are crimped inside, I drew grey lines to represent the cables. I'm wanting to know if it's possible to open up that camber I have a broken cable I need to replace.
