Stick On Curtain Rod Brackets
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by Eddy12, Apr 21, 2021.
  1. Eddy12
    Eddy12 Member
    36
    Aug 4, 2020
  2. Sjm9911
    9,000
    6,424
    Do you have an abs roof? If so i dont think they would work. Not sure where you want the curtains.
  3. Eddy12
    Eddy12 Member
    36
    Aug 4, 2020
  4. Sjm9911
    9,000
    6,424
    Some just sew it on the original tabs. Others use velcro. Those stick ons would probably work also. You could gromet and button them also. Lots of ways to do it.
  5. Eddy12
    Eddy12 Member
    36
    Aug 4, 2020
    Oh I didn't even think about grommets...great idea.
  6. threebeachboys
    threebeachboys Active Member
    446
    80
    Jul 18, 2005
    I can't imagine these would be a permanent solution. Command hooks don't even stay up for longer than a few days for me. The stickiness does not hold up well to changes in temperature from when the trailer is in use, to when it is stored.
  7. Sneezer
    2,663
    1,493
    Sticky stuff doesn't work well in pups. I have even tried the industrial adhesive velcro stuff, comes off after a year in the TX heat.
    You might look into tension rods - several have used them for adding extra curtains.
