TonyBCamping
New Member
- Jun 27, 2022
- 6
Hi, I plan on storing my PUP in my driveway while not in use. Aside from obvious things like locking receiver etc, what are some dos and dont's? TIA
thank you ! this is a pretty decent neighborhood but I am def putting in a tongue lock and lowering the stabs.I would look into a tongue lock etc to discourage people from hooking up to it. Maybe even lower your stabilizers to also further dissuade people. Just don't forget they are down yourself. Depending on your neighborhood may even want to either look into a battery lock or removing the battery to discourage people from taking it. You would want to disconnect the battery wires anyway to prevent parasitic discharge while the camper is in storage.
thank you ! I appreciate the infoI use a coupler lock that fits into the coupler like a ball. I also use a coupler latch lock. Probably overkill.
Use an RV cover. Not a plastic tarp.
Use vinyl tire covers to keep the UV light off those tires.
I chock the wheels, but I *also* put the wheel from the front trailer jack into a sort of "dish" that prevents it from rolling. That makes it impossible for kids to kick the chocks out and send it rolling down the driveway. They would first have to put the coupler on a hitch, raise the jack, remove the dish, lower the jack. That's really there just for the vandal / bored kids concern.
Lock everything, lower the stabilizers onto blocks, sent ant bait / rodent bait around.
