Storing Your Camper in the Yard - Nose Up or Nose Down??
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by BikeNFish, Apr 24, 2019.
How do you store your pup when it is outside?
  1. Nose up.
    15 vote(s)
    41.7%
  2. Nose down.
    13 vote(s)
    36.1%
  3. Level.
    8 vote(s)
    22.2%
  1. BikeNFish
    BikeNFish Well-Known Member
    4,155
    3,138
    Apr 24, 2017
    Maplewood, MN
    I finally was able to get my pup out of it's indoor winter storage home and parked it on it's summer storage area on a slab out in the yard. I have a major down slope behind the slab so I parked it with it's nose down to make it lean forward away from the slope, but was thinking that maybe it would be better to park it with the nose up for water drainage purposes. That got me wondering, "Does nose up vs nose down really make a drainage difference?"
    How do you store your camper outdoors and why?
  2. jmkay1
    7,043
    4,095
    I have always stored it nose up. 1) my reasoning is I have a front trunk on my camper and try to keep most of the water in the back of the camper vrs a waterfall all on the trunk. 2) it’s just easier. I can back up to get hitched without needing to adjust the hitch height. I worry about all the water going towards the AC unit instead and times I feel maybe nose down will be better.
    generok and PopUpSteve like this.
  3. J Starsky
    J Starsky Well-Known Member
    1,101
    991
    Aug 3, 2017
    East Central MN
    2% drainage is what they teach us in road work, right?
  4. bols2Dawall
    bols2Dawall S.W. Ontario
    1,497
    176
    May 19, 2010
    Lasalle Ontario
    up or down so long as not level
  5. J Starsky
    1,101
    991
    Aug 3, 2017
    East Central MN
    There might be a 2LiveCrew joke to make around here, but I refuse to sell it. Google Face Down if you want in... HAHAHAHA
  6. SteveP
    2,278
    947
    I've had rain leak in through the ac plenum with the nose down, I store level or nose up.
  7. mandinga
    mandinga Active Member
    197
    78
    Mar 4, 2014
    Ottawa, ontario
    However it comes off the hitch is how it is stored. My roof has a slight dome shape to it, so even level it sheds water. Between trips it stays level so I can open it up.
  8. jeeper88
    jeeper88 Let's go Camping and Jeepin
    921
    77
    Apr 24, 2011
    Ocala,FL
    Mine also has a slite dome so I go level.
  9. Snow
    11,812
    2,389
    Stored our pup nose down even with its front storage box.. Generally store both the utility trailer and the TT nose down as well.. Although this year due to work and weather schedules clashing the TT stayed level the whole winter..
  10. xvz12
    xvz12 Well-Known Member
    923
    589
    Apr 6, 2017
    ID
    I store ours nose up, I can get more slope on it that way, plus I don't need to fuss with it the next time I back into it
  11. Orchid
    Orchid Sharp Shootin' Grandma
    5,819
    2,744
    May 8, 2011
    Florida by way of WV and MD
    I chose level just because I open it up all the time. We live in Florida, so not like any long stretches where it's not used.
  12. Fuzzy Bear
    Fuzzy Bear Active Member
    540
    143
    Mar 3, 2004
    Norwalk CT
    I keep ours nose up. Prefer the runoff to go off the back end rather than onto the propane tank and wiring for the battery
  13. Anthony Hitchings
    3,148
    1,871
    Mar 2, 2019
    Oakland, California
    the perimeter framing will always hold a little water back on our ALiner roof, so it likely does not matter for me.
  14. kitphantom
    13,278
    2,400
    Our pups were stored nose down, since that's the way the driveway is sloped. The first one only had an LP tank, second one both battery and tank, but the run off didn't hit those directly. Neither had a/c or storage area to worry about.
    We do level the TT front-to-back, because we leave the refrigerator running most of the time during camping season. The cross slope of the driveway means is drains a bit to the left side. We did find that one battery box filled with rain because the drip line of the curved front dropped it right into the vent on that box. The boxes are off-set a bit, so it didn't happen in the other one. We drilled drainage holes as we couldn't figure out another easy solution.
  15. WingmanHG
    WingmanHG Member
    84
    80
    Mar 15, 2019
    Maricopa AZ
    With the cover and ac on the roof water can’t really pool so it’s level so I can open it up if I need it. Interesting question though
  16. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    Covered and nose up. Breathable cover is long enough to cover battery and spare tire on back. Small solar panel, under the cover, even helps maintain battery.
  17. generok
    3,353
    2,149
    Feb 7, 2013
    Anchorage, AK
    Nose up. I also had a trunk and wanted the snow melt to run off the back.
  18. Kampus
    Kampus Active Member Gold Supporting Member
    208
    206
    Jun 16, 2017
    Slate Belt, Pa
    Always store mine nose down...my only reasoning for this is that I had a leak at the rear seam when I bought it and wanted to avoid as much run off in that area as possible until I confirmed it was no longer leaking. The leak has been fixed, but the habit remains. I don't have tongue storage to worry about.
  19. jnc
    3,931
    1,193
    Oct 1, 2014
    South Central New Hampshire
    I keep the nose up just for Hitching reasons.
  20. Arruba
    Arruba Well-Known Member Gold Supporting Member
    705
    371
    Nov 28, 2014
    Central Oregon
    Me too
