stressed out by a "new to me" 1997 colman by fleetwood!!!
Discussion in 'Lift Systems' started by mbayer, Apr 20, 2014.
  1. mbayer
    mbayer New Member
    Mar 30, 2014
    I just bought a "new to me" 1997 colman. Tried to set it up today as the weather is so nice, and turns out, the locking mech doesn't lock when you open/pop it. Anyone know how to fix it, or if I have to do take it in to be fixed??
  2. ccptbo
    ccptbo Well-Known Member
    2,646
    102
    Jun 8, 2013
    Peterborough area, ON
    Can you be more specific? By locking mechanism you mean the crank, to crank it up??
    Also, can you tell us what model of Coleman you have...we know the year, but that's it. Thanks!
    Melissa
  3. rob2218
    rob2218 New Member
    1,549
    Feb 25, 2014
    need more specifics.
  4. bfahs
    bfahs Member
    427
    Oct 5, 2013
    Did you witness it being open & closed by the PO? If not, your mistake.
  5. rabird
    6,706
    304
    TX
    Page 49, Coleman Lift System doc
    Symptom
    Crank up/down not working
    Crank trailer up to full height and over-crank to re-engage clutch system
  6. mocamper
    mocamper Active Member
    1,168
    Aug 28, 2013
    I agree with previous post. Crank it up past where you think it should go to engage clutch. From the show me state.
  7. barb_dave
    barb_dave Active Member
    1,731
    Jul 22, 2007
    Wisconsin
    My step son and his friend used our camper one weekend and when they cranked the top down they over cranked it which caused the lock to not engage the next time I opened it. I cranked it up and and over cranked it and everything was working fine again.
  8. mbayer
    mbayer New Member
    Mar 30, 2014
    It is a 1997 Coleman by Fleetwood. I thought that I had over cranked it when I had it up this morning but I will try it again and see if that in fact fixes the problem. You can hear the sound of the ratchet as you are putting the roof up but if you were to let go it would not hold in place on its own. Seems like it would in fact be what people here are talking about with the locking mechanism so maybe I did not over crank it as I had thought.
    Thanks for the replies and if anyone else has anything to try please let me know. I will reply shortly as to if it worked or not.
  9. mbayer
    mbayer New Member
    Mar 30, 2014
    thanks guys!!! got it working !!!
  10. br9
    br9 Member
    740
    May 16, 2008
    Fort Worth Tx
    Lots of help there.
  11. Snow
    10,135
    1,045
    First Welcome to the Portal from the North Western edge of the GTA ... Can't help you with your roof problems, can offer you the opportunity to have some great camping fun ...
    Check out this link...
    http://www.popupportal.com/index.php?topic=80157.0
  12. ccptbo
    2,646
    102
    Jun 8, 2013
    Awesome! Great to hear!
  13. stef234237
    stef234237 Member
    200
    Apr 3, 2013
    My coleman does the same thing if you over crank it down. Just remember to be easy with those last revolutions. When cranking it down
  14. BuxCamper
    BuxCamper Member
    318
    Mar 29, 2003
    Bucks County, PA
    Re: stressed out by a "new to me" 1997 colman by fleetwood!!!
    If the crank is in the rear and you store the camper nose down rain gets in the crank tube and rusts things up so it would not lock until over cranked. I had to disassemble mine, clean everything with brake cleaner and reassemble. Worked fine after that. From then on when parking the PU I put some aluminum foil over the tube to keep water out.
    Sent from my Xoom using Tapatalk
  15. harfordhawk
    harfordhawk New Member
    24
    Jan 20, 2014
    Don't worry about it being "your mistake".. Your questions are welcome here and you will likely be able to help someone here with what you fix...
  16. mschepac
    mschepac South Jersey
    1,386
    Apr 22, 2008
    South Jersey
    Just a bit on the rude side....
  17. bfahs
    bfahs Member
    427
    Oct 5, 2013
    You are correct. Not sure why I was such as that is not normal for me.
    I apologize to the original poster. This is a great site and resource. I hope I didn't cloud that experience for you.
  18. mocamper
    1,168
    Aug 28, 2013
    Hey guys how do you get to the Frank assembly? I know how to get the plate off the bottom to grease and adjust there but not the entire crank assembly. From the show show me state.
  19. sportsfreaked
    sportsfreaked Member
    44
    Oct 15, 2011
    What year camper do you have and what make? I might have the info you are looking for. From the KC side of the Show me state.
  20. Jimbow
    Jimbow Active Member
    1,345
    Nov 30, 2012
    I never thought about nose up or down when storing. I will have to remember nose up.
