Stripped thread holes. Aliner 2012 Classic.
Discussion in 'A-Frame PopUps' started by cambo, Jul 22, 2019.
  1. cambo
    cambo Member
    30
    Jun 15, 2019
    Hi, This weekend I went around the camper and snugged up all the screws on the exterior and interior. I noticed that some screws would just spin and never really tightened.
    How can I fix this?
    Thanks!
  2. WrkrBee
    WrkrBee Well-Known Member
    3,629
    1,551
    Where are the screws that are spinning? Inside / outside? In cabinets? In the top?
  3. cambo
    cambo Member
    30
    Jun 15, 2019
    A few along the bottom edge on the outside.
  4. WrkrBee
    3,629
    1,551
    It may take a small shot of epoxy in the hole and put the screw back in. Stripped hole in wood, glue toothpicks or matches in the hole, and reinsert the screw.
    J Starsky and Rik Peery like this.
  5. joet
    4,971
    1,059
    I would be concerned as to why they wouldn't tighten. Did you remove any of them? And what did they look like...rusty. Rust is from water intrusion.
    durhamcamper likes this.
  6. cambo
    cambo Member
    30
    Jun 15, 2019
    Thanks. No rust, just spinning screws...
    Are there any preferred types of epoxy? I guess it needs to have a needle sized applicator to get into the small holes.
    Thank you
  7. sleach
    685
    150
    May 17, 2014
    Boulder, Colorado
    I recommend any of the metal-filled slow set epoxies. Take out all the loose screws and clean the threads with a brush. Mix up the epoxy, and push into the holes with a toothpick. Install the screws and wipe away any excess adhesive. Let sit for 24 hours.
    When dealing with really loose holes I push in the epoxy, then push in a toothpick and let it set for a day. Break or cut off the excess toothpick and install the screw.
  8. cambo
    cambo Member
    30
    Jun 15, 2019
    Thank you. Should I let the epoxy set before I reinstall the screws, or should the screws be installed while the epoxy is still "wet."
  9. bheff
    bheff Well-Known Member
    1,504
    911
    Feb 24, 2011
    NW Arkansas
    Follow the direction on the epoxy package.
    Rik Peery likes this.
  10. 1380ken
    1380ken Well-Known Member
    2,295
    699
    Nov 7, 2013
    Mass
    Elmers glue and golf tees
  11. J Starsky
    J Starsky Well-Known Member
    791
    585
    Aug 3, 2017
    East Central MN
    I'm a toothpicks in the hole or pipe thread tape kinda guy, when it comes to loose screws in wood stuff.
  12. cambo
    cambo Member
    30
    Jun 15, 2019
    Thanks. I'm not sure if the screws are going into wood or some other material. I'll check.
  13. Steve Ogden
    Steve Ogden New Member
    17
    Aug 21, 2018
    I second the toothpick suggestion. It's not permanent.
  14. jadmt
    jadmt Member
    62
    19
    Mar 26, 2019
    old thread but some glues/epoxies will dissolve the foam used inside the walls.
  15. Steve Ogden
    17
    Aug 21, 2018
    My local hardware store says the gold packaged LiquidNails will dissolve the foam/styrofoam. They say the blue package LiquidNails is silicone based and safe for styrofoam. I haven’t tried to see, but think I’d experiment on something other than my Aliner first. :)
  16. Sjm9911
    6,554
    3,929
    All glues should say if there safe for foam. Just read the fine print, that gets harder as you get older. On mine i just used the next size bigger stainless screw, all the screws were loose. Any of the above options are good. Wood glue is also good around the toopicks.
    cambo likes this.
