Styrofoam for corner section on a 1996 Jayco pop up
Discussion in 'Camper Restoration Projects' started by Vandys, Jan 10, 2020.
  1. Vandys
    Vandys New Member
    Sep 30, 2019
    I’m in the process of repairing the wood underneath the roof due to water damage. In the process, I had to remove the styrofoam that serves as the support from the transition between the roof and the rear section of the roof. Hope that makes sense. Looking to find a place that sells speciality styrofoam.
    The styrofoam has a curved back, to match the aluminum roof curve. The inside portion of the styrofoam has grooves running the length of the foam. I’m sure pictures would help and will try and get some to get a better visual.
  2. Raycfe
    15,397
    1,573
    If I were looking for a large curved piece of styrofoam, I would check with a store that sells TVs etc. Most of them are packed well with styrofoam. My next option would be expanding spray foam insulation. Spray foam can be cut and shaped after it stops expanding
  3. Mat Kyne
    Mat Kyne Member
    46
    61
    Jan 22, 2018
    Central Texas
  4. Vandys
    Vandys New Member
    Sep 30, 2019
    Thank you. I will look into those ideas.
