Suburban hot water heater will not ignite
Discussion in 'Propane - Got Gas' started by Geezerbill, Sep 15, 2021.
  1. Geezerbill
    Geezerbill New Member
    Sep 1, 2011
    I have a 2007 Fleetwood Santa Fa with a Suburban gas only hot water heater. This week on the next to last day camping I had to switch bottles. Then my hot water heaters pilot light would stay on but the main gas burner would not ignite unless I stuck a sparkle into the burner compartment near the gas tube after considerable gas has built up. I have checked for obstructions and the tube and gas orfice are clear. This is the first time this has happened.
    Also, I tried to remove the anode to check it and even with Teflon tape on it I can’t budge it. I will get a six point socket tomorrow but I have a bad feeling wether I should continue to try and remove it.
    Any help on these two issues will be greatly appreciated. Thank you.
  2. Sjm9911
    10,641
    8,024
    Shut off your propane tank and open again slowly.
    neighbormike and theseus like this.
  3. theseus
    theseus Living the Darkside... Silver Supporting Member
    3,359
    809
    Feb 6, 2007
    Centerville, OH
    Go gentle with the socket and all should be fine. No smacking it with a hammer. I use a socket to remove mine after every trip.
  4. Geezerbill
    Sep 1, 2011
    Thanks, I’ll try that tomorrow.
  5. Geezerbill
    Sep 1, 2011
    Ok, thank you. After all these years it’s pretty rusty looking. Should have done it years ago but I’ll try. Darn old socket size so I have to buy a socket tomorrow.
  6. theseus
    3,359
    809
    Feb 6, 2007
    Centerville, OH
    You might try PB Blaster on it. Soak it and let it sit for an hour or so…
    RonDad likes this.
  7. McFlyfi
    McFlyfi Well-Known Member
    754
    456
    Aug 1, 2014
    Thousand Oaks CA
    Does your stove function properly? If it doesn't, it could be that the shut off on the new tank tripped. As mentioned above, close the valve, wait a minute, and open it again, slowly. It could also be a bad regulator. My water heater exhibited this behavior, and my stove wouldn't stay lit. A bad regulator was the culprit.
  8. Geezerbill
    Sep 1, 2011
    Thanks for the suggestion. Stove, furnace, and ref all work perfectly. Here’s what I did today.
    Filled original bottle that went MT.
    Purchased and installed a new pigtail with the large knob and connected the refilled bottle. Still no start.
    Reinstalled the metal shield in front of the burner chamber and pilot light. NOW RUNS FINE. STARTED RIGHT UP. I assume the shield must create a chamber to create the gas buildup for ignition. ALL IS GOOD AND THANK YOU ALL FOR SUGGESTIONS.
    Regarding the anode. I was able to remove the old one with the 1 1/16” socket I purchased this morning. Old one was pretty bad!! Vac’d out tank with a piece of sprinkler irrigation tubing attached to vac and installed new anode. Will pressure test on next trip. THANKS TO ALL WITH YOUR SUGGESTIONS. VERY HELPFUL.
    theseus and Allamakee County like this.
  9. F. Jake Glotz
    F. Jake Glotz New Member
    17
    Sep 1, 2021
    You might also check and exercise the pressure relief valve when replacing the anode rod too. That is the real safety piece on the water heater.
  10. Geezerbill
    Sep 1, 2011
    Yes. That’s for sure. Thanks!
  11. Westlake2019
    Westlake2019 New Member
    25
    Jul 28, 2019
    Athens Texas
    Is there a way to have an electronic lighter on a 2010 Westlake to light the hot water heater? It is a pain to light. I have to make a tent around the outside of the camper to be able to light it. I use a torch-type lighter but I have to hold it perfect for over a minute. I would love to push a button to light.
  12. theseus
    3,359
    809
    Feb 6, 2007
    Centerville, OH
    I would have thought that a 2010 Westlake would have had a dsi water heater. A dsi or direct spark ignition unit is flip a switch to turn it on and it lights when it needs to. So your Westie has a pilot light?
  13. Sjm9911
    10,641
    8,024
    If it takes a long time to light maybe its in the wrong position or the thermocouple is starting to go bad? I never had to tent off the area when i had mine, it did take a minute probably to heat up though.
  14. Westlake2019
    25
    Jul 28, 2019
    Athens Texas
    Yes, it has a pilot light. I'm wondering if it can be converted to an electronic or do I have to get a newer hot water heater.
  15. theseus
    3,359
    809
    Feb 6, 2007
    Centerville, OH
    A new dsi water heater would be about $250ish. When I have replaced one I always go dsi. I believe though there auto igniters that can be installed for pilot light units.
  16. Westlake2019
    25
    Jul 28, 2019
    Athens Texas
    Looks like a new one-off Amazon is less than $350.
    Suburban Manufacturing Suburban Co 5238A Sw6D W/H 6 Gal Dsi
    Brand: Suburban Manufacturing
    List Price: $470.59 Details
    Price: $323.18
  17. Westlake2019
    25
    Jul 28, 2019
    Athens Texas
    If there is an auto igniter for a pilot unit that is what I would go for so I will start researching that option.
    Thank you all for your input.
  18. Sjm9911
    10,641
    8,024
    I haven't sceen one, it dosent mean they dont exist. I have seen a ellectric ellement that will go into the anoid spot that makes it ellectric. But have not heard of a conversion to auto igniting.
  19. Westlake2019
    25
    Jul 28, 2019
    Athens Texas
    Also, does anyone have any idea why the furnace will not fire off? I set all year 2020 as we built a new home. No camping at all. The thermostat runs the fan when you switch it to fan but that is all. If you set it to say 60 degrees, nothing happens.
  20. Sjm9911
    10,641
    8,024
    Maybe you problem is the propane regulater, or you turned on your tank too fast? As long as you set the thermostat higher then the ambient temps, and have it switched to on or heat, and the switch on the heater itself is on , it should light or blink a code. ( the code depends on model and year of the heater).
