SWAY CONTROL
Discussion in 'Tow Vehicles, Hitch & Towing' started by Beekeeper1, Jun 16, 2019.
  1. Beekeeper1
    Beekeeper1 Member
    43
    Feb 12, 2018
    Whitman Creek, WV
    I have a 280 Palomino Pony. Total weight is 1285 empty. TV is 2004 olds bravada. Towing capacity 3500 pounds. I purchased a Curt SWAY control kit. Now I am wondering if I really need to install it on such a light trailer. Any thoughts or advice ?
  2. joet
    4,970
    1,059
    Since you have the bar, go ahead and install it
    theseus likes this.
  3. giadiep
    giadiep Active Member
    430
    192
    Sep 5, 2015
    Syracuse, NY
    I would not bother. Your tv weighs at least 2x the trailer. If leveled properly, you won’t experience any sway.
  4. nineoaks2004
    7,869
    3,475
    Dukes, Fl
    Try towing the unit first with the load you will carry and speed for when you go camping. If there is no sway then don't worry about installing, if you get any sway then install it. Good Luck and happy Camping
  5. Orchid
    Orchid Sharp Shootin' Grandma
    5,661
    2,495
    May 8, 2011
    Florida by way of WV and MD
    I wouldn't bother unless you experience sway, which you likely will not. You have to remove it to back the camper, so just adds to the list of things to do/forget.
  6. Minimalist
    Minimalist Active Member
    251
    49
    Nov 30, 2015
    Why would the weight of the TV matter of you get sway or not?
    xxxapache likes this.
  7. WrkrBee
    WrkrBee Well-Known Member
    3,573
    1,524
    A 1500 lb trailer has less effect on a 5500 lb tow vehicle, than a 3500 lb vehicle. I want my dog to be bigger than its tail.
  8. Minimalist
    251
    49
    Nov 30, 2015
    You are talking about controlling sway. My question was why a bigger TV would prevent sway from happening. Two very different things.
  9. WrkrBee
    3,573
    1,524
    A larger tow vehicle does not allow the sway to start, preventing sway.
  10. xxxapache
    3,147
    1,140
    I see plenty of small trailers swaying behind large vehicles.
  11. WrkrBee
    3,573
    1,524
    Sure, due to being loaded wrong, frame issue, or axle alignment issues. Even a large vehicle can't make up for some equipment. I'm referring to normal properly loaded trailers. A large vehicle will control a trailer better than a small vehicle. I see some people tow a huge boat behind a small pickup and wonder what they were thinking.
    bols2Dawall likes this.
  12. Minimalist
    251
    49
    Nov 30, 2015
  13. Minimalist
    251
    49
    Nov 30, 2015
    You are again going back to a larger vehicle can control the trailer better. That is not disputed. At least not by me. What I am saying is if you have the set up down you don't need a larger truck because you won't have any issues.
  14. WrkrBee
    3,573
    1,524
    We are pretty much saying the same thing. Most people here are pulling pop ups, and we benefit from a larger vehicle for trailer control so we are not borderline if something happens quickly.
  15. Annunzi
    Annunzi Member
    42
    Jun 14, 2019
    Vancouver Island, British Columbia
    I wouldn't install them, our tent trailer is 1600 pounds dry and we've never had a problem with sway. I see the sway bars on travel trailers that are heavier and less aerodynamic than a tent trailer.
  16. chefaleslie
    chefaleslie Always looking for a great MOD
    294
    28
    Feb 9, 2013
    Sisters, OR
    I have one, and use it. Better to have it and not need it....
  17. bols2Dawall
    bols2Dawall S.W. Ontario
    1,473
    166
    May 19, 2010
    Lasalle Ontario
    Totally necessary , take it back
  18. Eric Webber
    Eric Webber Active Member
    276
    172
    Jul 7, 2018
    Montreal, Quebec, Canada
    I went with the Andersen. It’s a sway control WDH that only weighs a very little bit and has no issues with backing in.
  19. Eric Webber
    276
    172
    Jul 7, 2018
  20. RockyRoo
    6,570
    198
    Jun 8, 2012
    My personal thought, put it on. You are better to have and not need than to need and not have. I ran sway bars on both my pups, the cost and time to install/remove are minimal and when compared to the situation you could find yourself in if you don’t have it, and I towed mine with Suburbans, not little undersized vehicles. You already have it, use it.
