Swing out jacks
Discussion in 'Stabilizing Your Camper' started by xRampagex, Apr 10, 2020.
  1. xRampagex
    xRampagex Member
    45
    Sep 6, 2019
    Michigan
    94 Palomino Stallion has the swing out stabilizers. What do I do when I'm on unlevel ground and there isn't enough ground clearance to swing them out?
    Thanks
  2. Sjm9911
    10,626
    8,008
    Im guessing you eaither dig a hole or put blocks under the campers wheels to raise it.
    1380ken likes this.
  3. Snow
    11,800
    2,380
    Or swap them out for crank down stabs.
    Sjm9911 and bheff like this.
  4. bobinfleet
    bobinfleet Well-Known Member
    1,360
    573
    Sep 2, 2011
    Hampshire UK
    Or move to a level position:wink:
  5. billbillbillbill
    billbillbillbill Active Member
    135
    97
    Sep 4, 2012
    SLC, UT
    On my smaller Yuma trailer, I found at times that I had to either lower/raise the tongue to get enough clearance to swing them out then I could level it out front to back. I would then crank up the roof and then tension the stabilizers. I don't remember ever not being able to get them down but there were times that they were tight before even extending them at all.
    I had planned to swap to BAL crank stabilizers but never did before replacing the trailer.
  6. Wrenchgear
    3,583
    837
    Aug 5, 2010
    5 Star Eagle Camper
    Yes, as said above by billbill, I just crank up, or lower the tongue until I can swing the stabs down. Then re-level the Pup front to back and set the stabs. Its pretty easy.
  7. Wrenchgear
    3,583
    837
    Aug 5, 2010
    5 Star Eagle Camper
    If you could come over and do this for me, that would be great! I'll be here next week, and probably for the next 6 months. I'll sit about 10 feet away and yell encouraging directions to you. You'll need to stop in at Princess and grab 4 of those stabs for me. Oh yeah, and my Argon bottle ran out the other day too, so you might want to stop in at the fab shop at your work and bring me a cyl of that. Thanks man!
    WVhillbilly likes this.
  8. tombiasi
    6,639
    2,209
    Need to take care when cranking the tongue back up that there isn't too much weight on the stabs.
  9. Wrenchgear
    3,583
    837
    Aug 5, 2010
    5 Star Eagle Camper
    I know, that's why Snow should come over to my place and replace my telescoping ones with some crank downs! :)
  10. Snow
    11,800
    2,380
    You can't afford my services..
