Switch bunk ends?
Discussion in 'Camper Restoration Projects' started by Katskamper, Dec 1, 2016.
  1. Katskamper
    Katskamper Active Member
    758
    207
    Nov 21, 2015
    Fort Worth, TX
    thats probably easier!
    Kat
    2003 Skamper Sport
  2. Katskamper
    758
    207
    Nov 21, 2015
    Fort Worth, TX
    the king bed track crosses the front door when closed
    Kat
    2003 Skamper Sport
  3. SHFL
    SHFL Active Member
    463
    118
    Jan 6, 2015
    Florida
    I've thought about your question... And it would be A LOT of work; first for the mod, and then during set up.
    If your canvases zip to separate the bunk ends from the center, you can swap the bunk end canvases.
    Then you swap the bed platforms. I am not sure how YOUR king slides out, but my rail has two pieces on each side that '"telescope." You will have to see if you only need to swap the platform portion of the rail, or the entire rail assembly.
    Finally, you should definitely put some platform-to-ground supports on the king bed, because without a huge weight in the front bunk, you will likely tip the camper. You might also have to modify the bed platform so that the load from the ground support not concentrated in a small area, causing it to punch through the platform.
    Every time you set up the camper, you will have to deploy the platform-to-ground supports and adjust the length depending on the site characteristics. AND you need to check the bed level during you stay because "some settling may have occurred."
    I can understand why you are thinking about doing this, but maybe you can find a way to work around the hitch. Perhaps you could invent a bed push/pull assist rod for the front end. It could have 2 poles to the ground, with height adjustable legs (to enable a level pull out), and a level pole or beam that attaches to the grab handles/straps. I think developing this would be a better, and possibly more profitable, use of your time. Based on what I've read in your blog, you can do this!
  4. rjhammetter
    rjhammetter Husband, Dad, Engineer & Camper
    252
    92
    Mar 1, 2016
    Wisconsin
    You will have to work around the hitch regardless of what size bed is on which side. I sort of made a quantum leap that the core problem you described is the king becoming difficult to push in/pull out, in which case, I'd try lubricating or replacing the track system and rollers. Like others have said, your proposal seems more like a ground-up rebuild with high cost and risk.
    Mine pull out and push in like butter (I'm not saying that to brag - it's just in good condition). It doesn't matter which bed would be on which side with our hitch.
  5. dougfam
    dougfam Member
    225
    Feb 15, 2014
    I have often thought about doing this task on our camper. Mainly so we wouldn't have to unhitch for a single night stop on our road trips. We have a front queen and rear full, so I don't think the weight will be that much different for us. It's just finding the time to take the task on. I'm sure it would take a few hours to complete.
  6. R00
    R00 Active Member
    1,286
    17
    Aug 10, 2014
    In my buddys trailer I added a small handle under the mattress on the bunk ends. He pulls the bunks in 3/4 of the way from inside.
  7. Katskamper
    758
    207
    Nov 21, 2015
    Fort Worth, TX
    wow! thanks for the serious & silly responses.[emoji79]
    1. im single, go camping alone most times, or with older lady friends who dont have my strength.
    my rig, my setup/teardown.
    2. mom bought the popup & i inherited it when she died in '13. ive already put in several long weekends of maintenance & upgrades on it.
    its been garage kept its whole life. looks new.
    on my current budget, cant afford to buy different.
    in the distant future, most likely, i will do a custom build to get what i want.
    but for NOW:
    yes, i lubricated the metal parts. its the plywood on the King bed that sags in the middle & drags on frame when pushing/pulling. i keep replacing the loop catchers underneath.
    yes, i use the additional bed supports on king end
    the previous owners didnt.
    yes, i attached loops made of rachet strap so i could use a closet rod pole to help pull. might have to do that inside too.
    i even added larger stronger caster wheels inside on front wall to help support it while moving.
    i have considered bed to ground support because it moves- and ive read "the bed broke" postings!
    Sent from my iPad
  8. chipperone1
    chipperone1 Member
    386
    Aug 27, 2011
    I think it is very possible to do and should require very little modifications if any at all
    The bunk ends zip up in the same place so the canvas should be an easy switch
    The bed ends fit now so swapping ends should be easy
    You may need to do something about the bed supports, one end or the other may work when switched
    Do it and don't forget the pics.
  9. Orchid
    Orchid Sharp Shootin' Grandma
    5,585
    2,399
    May 8, 2011
    Florida by way of WV and MD
    Sounds like just replacing the wood on the king would do the trick. However, I have no clue where to find a piece of wood that large. Maybe some kind of special order. It would be so crazy heavy that it may be worth having an RV place do it.
  10. jumpoff
    jumpoff I'm in a camping state of mind
    1,553
    190
    Nov 3, 2015
    North East Florida
    If the wood is sagging maybe you could just flip it over....???
  11. roybraddy
    roybraddy Well-Known Member
    2,306
    848
    Mar 23, 2016
    King George, Virginia
    We have a similar layout with our OFF-ROAD 2008 STARCRAFT R/T POPUP.
    Roy's image
    This is our floorplan
    Roy's image
    I have a couple of reasons not to swap the tent beds.
    I really like the idea of having the front deck under the bed to keep animals and other creatures from wandering under our bed setup when we are camping. Gives us extra security...
    Another reason is our tent bed area also has the cassette potty and shower setup on this end of the popup and we have a pull curtain that separates this whole area from the access door from the other side... The pull curtain adds some privacy... With our current layout we can walk right up to the tent bed whereas if it was on the other end we would have to climb over the wrap around seating to get into the bed.
    There is only two of us usually camping and the area behind our wrap around seating always becomes our catch all area... That probably would not work out very well being our master bed area.
    Roy's image
    I also think you will run into some problems actually swaping the two tent beds... I would look into why you are having difficulty pulling out the bed ends. Mine works just fine. I did have to modify the seal to work better sealing off the air gaps between the tent bed floor and the end of the trailer walls... The OEM seal allowed you to look under the pulled out and see daylight. It would allow night insects come inside when we had lights on inside the trailer... Also was another cold spot to deal with keeping everything warm inside during cold nights.
    Roy Ken
  12. silvermickey2002
    4,744
    522
    Sep 11, 2008
    Morris County, NJ
    As for the king plywood sagging...
    Maybe you can install some cross bracing supports to get rid of the sag? On our Fleetwood queen bunk there is a support/brace that is mounted under the bunk that runs front to back under the plywood.
  13. Orchid
    5,585
    2,399
    May 8, 2011
    Hmmmmm .... that's a great idea. Once again, I overlook the obvious. [;)]
    Or this ...
    I have enjoyed some of the goofy answers on this thread, but I really would want to fix the problem too.
    If that's your actual camper in the first photo, it's gorgeous and looks brand new.
  14. Katskamper
    758
    207
    Nov 21, 2015
    Fort Worth, TX
    i think so. separating zippers in all 4 corners.
    support poles will need adjusting though.
  15. Katskamper
    758
    207
    Nov 21, 2015
    Fort Worth, TX
    catalog glam shot. but almost new for its age.
  16. Katskamper
    758
    207
    Nov 21, 2015
    Fort Worth, TX
    the plywood is pieced, with a thin strip covering the seams underneath. i added headliner vinyl to the bed deck to prevent splinters. flipping wood requires deconstructing the frame.
  17. Orchid
    5,585
    2,399
    May 8, 2011
    No good deed goes unpunished. [:(]
  18. tjwagers
    tjwagers Member
    189
    Sep 12, 2010
    Why not add a handle on the inside like another poster suggested? You could make it out of rope so there wouldn't be clearance issues. Plus it would be a lot less work.
  19. Mr Zip
    Mr Zip Member
    511
    Jan 2, 2009
    North Ridgeville Ohio
    Good luck with this project.
  20. sawdusty
    sawdusty San Antonio
    866
    42
    Nov 9, 2014
    San Antonio
    I vote for the metal brace in the center, underneath, front to back so support the pieced plywood and provide a smooth surface for the pull out to rest on during the pull.
