Tank Leaking at Valve when Connected
Discussion in 'Propane - Got Gas' started by mercman, Jul 8, 2012.
  1. mercman
    mercman Go Ahead, Be That Happy Camper!
    2,939
    47
    Jan 7, 2007
    Western MA
    Last week before our big trip I switched out tanks to a fully filled one. When we got to our site and set up, I opened the valve and heard and smelled gas. I disconnected and reconnected with no luck so we left it disconnected and valve off. When we got home, I switched out tanks with the BBQ one, no leak. Put original leaky tank on BBQ and it leaked there also. So I know the issue is with the tank and not the pup connection.
    The O-ring in the valve looks "smooshed" compared to the non leaking tank so I am thinking the O-ring is the culprit. Is this O-ring replaceable? Do I need a special tool or technique to get the old off and new on? and finally, is this a hardware store item or a specialty item from a propane dealer?
    Thanks in advance!
  2. Raycfe
    17,005
    2,590
    Anyplace take fills propane bottles should have the oring because they have to replace them often because of all the use the filling coupler gets.
  3. cwolfman13
    cwolfman13 Active Member
    3,218
    Feb 9, 2011
    Where did you get the tank? Was it an exchange or a tank you already had and had it filled. If it was an exchange, take it back and tell them it's bad; they should give you a new one.
    If you had it filled, I'm surprised they didn't notice it was leaking. May be time to swap that tank out.
  4. mercman
    2,939
    47
    Jan 7, 2007
    Western MA
    The tank is mine and is only about 4 years old. It didn't leak before the last fill up so my guess is it got "torqued" too much when being refilled.
    Any thoughts on how to pull out the old O-ring and put in the new one?
    Thanks!
  5. cwolfman13
    3,218
    Feb 9, 2011
    Personally I'd just swap it out or take it to a propane station and see if they can fix it. My guess is that they'll just tell you to swap it out for a good tank.
