Tell me about your wheel chocks
Discussion in 'General Camper Setup / Take Down' started by eoleson1, May 3, 2021.
  1. eoleson1
    eoleson1 Well-Known Member
    3,613
    1,732
    Jul 5, 2011
    Macomb County Michigan
    This weekend we had a site that wasn't exactly level. It was sloping both front to back and roadside to curbside. I back her in, then pulled her up onto the leveling blocks. I put my camco chocks on the non-leveled wheel and started to disconnect from the TV. When it came off the ball, the trailer rolled back about 3 inches until the chock dug in and held. It almost rolled off of the leveling block. I got it braced up and stable for the weekend, but I thought there has to be a better way. I looked online but didn't see any chocks better than the camco style.
    What advice can you give me here? I thought maybe switching to a BAL leveling system may help?
    Afterthought: If I am plugged into shore power, can I pull the breakaway switch and use the camper brakes like a parking brake? Would that pull the battery down faster than the converter can charge it back up?
  2. WrkrBee
    WrkrBee Un-Supported Member
    6,539
    3,448
    Sounds like the leveling block was not level. I've found that my chocks work better flipped over, with the flat side to the tire and the curved side down.
    You don't want your electric brakes actuated all the time. Could burn the coils out, then you don't have brakes. The break-away switch is for emergencies.
  3. Groomporter
    Groomporter Well-Known Member
    297
    365
    Jan 30, 2021
    Minnesota
  4. Sjm9911
    10,629
    8,010
    I may be the oddball, but i chock both sides of the camper. You can put a board under the chock also. So like a wedge under the chock. I have one set of the camco type chocks and one set of the harbor freight rubber ones. I sort or like the rubber ones better. I think they slip less. Other ideas, if its wet out roll the camper back and forth a few times to compact the ground.
  5. SteveP
    2,257
    931
    Your trailer is too heavy for a Bal leveler but they also make a single wheel chock, which I highly recommend. No one's mentioned the Camco chocks that lock into the leveling blocks.
    On steep slopes it's best to hammer the downhill chocks into place so they have some bite before you release the trailer. Always leave your chains and break away cable in place until after you lift off the hitch and verify your trailer is secure.
    hayyward, Nick81 and generok like this.
  6. xxxapache
    4,089
    2,372
    I chock both sides of the trailer and front and back sides of the wheel most times. I have dual axles and also use a X chock between the tires on one side.
    DiamondGirl, generok and Sjm9911 like this.
  7. AndreD
    AndreD Active Member
    102
    47
    Jul 24, 2020
    Great White North
    what pop up do they have? I thought the bal leveler could handle all pop ups.
    woodentoy likes this.
  8. SteveP
    2,257
    931
    Not a popup based on his sig.
    2018 Shasta Oasis 18BH
    2021 Dodge Durango
    2006 Chevrolet Colorado
    [put&hy]
    [suv&hy]
  9. AndreD
    102
    47
    Jul 24, 2020
    Great White North
    Do signatures not show on the mobile platform? I don’t see that (asking for future reference)
  10. Sjm9911
    10,629
    8,010
    Turn you phone sideways, then they should show.
    DiamondGirl and AndreD like this.
  11. SteveP
    2,257
    931
    No one's mentioned the Camco chocks which lock into their leveling pads.
    On steep slopes it's best to hammer the downhill chocks into place so they have some bite before you release the trailer. Always leave the chains and break away cable connected until you have lifted the hitch off the ball and verified that the camper is secure.
    xxxapache likes this.
  12. AndreD
    102
    47
    Jul 24, 2020
    Great White North
    Well I’ll be… learned something new today. Thank you
    kcsa75 and Sjm9911 like this.
  13. Sjm9911
    10,629
    8,010
    Im with you, i feel that the 4 chocks stabilize the camper a lot better then one side. Now i dont have the x chocks, but mine is solid and have no wobble when set up.
    DiamondGirl likes this.
  14. generok
    3,318
    2,100
    Feb 7, 2013
    Anchorage, AK
    Same. X Chock both sides, and normally one side is in the Andersen levelers, which also act as a chock. I also have a small set of stackable chocks that work surprisingly well.
  15. xxxapache
    4,089
    2,372
    Yep, I use the Andersen levelers also. They are fantastic.
    Mark CASTELLANI and generok like this.
  16. kitphantom
    13,220
    2,325
    We have three styles of chocks. In general, the BAL chock (not leveler - we use Lynx blocks for that) is always used. For the other wheel, it's either a standard plastic chick, or the Lynx one(s) that goes onto the blocks. We got tired of the light plastic chocks blowing out from under the tires on hard surfaces, even when set with a rubber mallet.
  17. Groomporter
    297
    365
    Jan 30, 2021
    Minnesota
    I'm showing my age here, but I confess discussions of chocks always make me think of the old vitamins for children... [:O)] [:D][​IMG]
    hayyward, JimmyM, jbalash and 4 others like this.
  18. Snow
    11,801
    2,380
    I have 3 different types of chocks.. I have 2 knock-off version of the B.A.L dual wheel chock, 2x homemade between the wheel chocks (looks similar to the cheap yellow CamCo ones and the 3rd set of chocks are the chocks I used with the popup for years and still use, 8inch long piece of cedar 4x4 post cut in half at a 45 angle.. All 3 styles work great with my Lynx Levelers..
    generok likes this.
  19. Sneezer
    2,856
    1,690
    I use the BAL single wheel chock, and the BAL leveler on the other side. Guessing your TT is a single axle? If the BAL will fit, it is an excellent chock.
    You can also get chocks that interlock with Lynx if you use those. If the site were badly sloped I would try and use my lynx to stairstep up to get a level platform, assuming the BAL could not handle it. However, with my pup severe grades usually mean I can't set up, as mine is lower than most pups. I had one site that was bad enough that there was no room to swing down the stabs on the back. Ended up using a wheel jack instead for that trip.
  20. Drufus
    Drufus Member
    31
    63
    Mar 19, 2020
    I also use the HarborFreight chocks on both wheels. Solid.
