Test Run, first trip out with the (ntm) camper
Discussion in 'Let me tell you about my trip' started by Terry Mahoney, Oct 20, 2019.
  1. Terry Mahoney
    Terry Mahoney New Member
    Oct 8, 2019
    Maryland, USA
    I took the 91 Coleman Shenandoah up to Caledonia State Park in Central PA northwest of Gettysburg.
    I wanted to see what it needed sans family; if I experienced any bumps along the way, I could adjust before the family came out.
    1) Check the tow hitch ball. Looked like the same size but was smaller than what I had on there, but I had a spare of the correct size.
    2) Check the wiring. First time I had towed it. At some time, apparently the trucks end of the tow wiring got torn off. I had to fake it.
    3) Everything else was great!
    4) it got wicked cold, but other than that, it was a pleasure. Mattresses were perfect, it was waterproof in the rain, no leaks.
    5) Electrical system worked great. Every light lit and every socket worked.
    I still need to find a water tank and work on getting the propane stove working. It also has the wiring for a heater, but no heater attached. Have to look into that.
    Any suggestions on the water tank and heater would be appreciated.
  2. Sjm9911
    4,734
    2,469
    Definitely fix the wiring to the pup. The blinkers on the highway are needed!
    For the heater, if you are only at ellectric sites get a portable ellectric one, or look into a mr. Buddy heater. Cheaper then the built in ones.
    What type of water tank do you need? Under sink one or one that is under the pup?
    Terry Mahoney likes this.
  3. nineoaks2004
    7,399
    3,143
    Dukes, Fl
    Glad you enjoyed the trip, each time out is an adventure unto it self, and most times a learning adventure. Good Luck and keep on camping
  4. Terry Mahoney
    Oct 8, 2019
    Maryland, USA
    I think it goes under the dinette seat, unless it goes outside and I feed the clear tube out the hole and into it.
    Thanks,
    Terry
