The right power drill to raise my pop up roof
Discussion in 'Camping for the Medically/Physically Challenged' started by Balone42, Jan 25, 2011.
  1. Coachmen 2007
    Coachmen 2007 New Member
    Aug 16, 2018
    The kobalt 24 volt drill is very powerful with 650 inch pounds of torque that almost worked on my large roof with a/c. It would raise the heavy roof fast but went in overload mode.. might work for many other smaller campers. I would at least try this drill.. I had to go with the kobalt corded 9 amp. That works great
  2. SgtRon
    SgtRon Member
    53
    37
    Jun 7, 2017
    Florida
    I just bought a Hitachi corded D13VF drill, rated at 416.6 in lbs torque. I put in the jinnie and tried cranking up the top on my 2003 Starcraft 2410 pup. The top went about half way, then died. I finished it by hand, I guess 416 in lbs is not enough torque to do the job. Does anyone have a specific brand & model number of something that will do the trick?
  3. GreyFox
    GreyFox Well-Known Member
    1,487
    716
    Oct 10, 2018
    S Ontario
    You mean 416 in/lbs, not ft/lbs. [:O] Your drill, though it's top speed of 850 rpm is way too high, would have easily lifted the roof on my previous 2000 Santa Fe, just as did my DeWalt DW987 which was rated @ 450 in/lbs but that's no guarantee it would lift the roof on any popup that uses a different lift system. Keep in mind that most corded drills aren't rated for torque simply because most don't develop much at all - for that you want a cordless drill, 18 volt to 24 volt. Be aware though that when shopping some manufacturers, DeWalt being one, don't rate their cordless drill torque ratings in inch/lbs but rather MWO (Maxiumum Watts Out) - and explanation is here https://www.protoolreviews.com/buying-guides/max-watts-out/13109/ A friend of mine owned a 12' Camplite and even my corded Bosch 1034VSR drill which is unusual in that it's rated at a whopping 767 in/lbs wouldn't lift the roof. These days I own a DeWalt 20 volt DCD785 lithium ion cordless drill, don't recall it's torque rating, but I'm confident it will easily lift the 10' roof on our NTU Resolute. In your case, try a cordless drill but if that doesn't work you may be stuck with cranking your roof manually.
  4. SgtRon
    SgtRon Member
    53
    37
    Jun 7, 2017
    Florida
    I physically am not able to crank my pup any longer. My healing after the heart surgery 11 months ago is going very slowly, my age (70) may be a contributing factor. I read the article on MWO for DeWalt, but I'm still not sure what I need to buy. I guess I need a low speed lithium battery powered 20v cordless drill that can achieve somewhere around 500-550 in lbs of torque. Does that sound about right?
  5. GreyFox
    1,487
    716
    Oct 10, 2018
    S Ontario
    That's about right EXCEPT to say there are no guarantees because each lift system is different. I suspect the only way you'll know is to try it, if it doesn't work then return the drill you bought for this purpose. Keep in mind however that even if you use a drill you still have to hang onto it pretty tightly and that does take some effort. Depending on where your lift system crank attaches it might be possible to design a drill support as I did for our Santa Fe so all the force is absorbed by the mount. Here are several pics to illustrate ...
    https://photos.google.com/share/AF1...?key=Y0tiYWFzQl8xdGRCRmwwOV90TXBtYlpOZHdRc3VB
  6. jnc
    3,928
    1,173
    Oct 1, 2014
    South Central New Hampshire
    Harbor Freight has a 20v Impact Driver that should lift you roof. I use one on my Niagara with an AC on the roof. I need to add that if you don't have AC on the roof and the drill you had did't work your lift system may need some grease & oil.
  7. GreyFox
    1,487
    716
    Oct 10, 2018
    S Ontario
    Unless one builds a drill mount as I've described above I wouldn't recommend any drill for this purpose that doesn't come with a torque handle - as far as I can tell this HF drill doesn't. This would be especially important for someone with limited physical ability.
  8. jnc
    3,928
    1,173
    Oct 1, 2014
    I guess some folks would need the extra handle to avoid twisting their wrist. If it was that much trouble I would add a gear reducer to the Pup than a 5 yr old could do it.
  9. GreyFox
    1,487
    716
    Oct 10, 2018
    S Ontario
    My post was in reference to SgtRon who is recovering from heart sugery and who will surely want the least stressful way to lift his popup roof. An alternate solution for him might also be to see if there's a power lift system that could be fitted to his popup.
  10. SgtRon
    SgtRon Member
    53
    37
    Jun 7, 2017
    Florida
    I think I've found the right drill. I picked up a Kobalt brushless 2 speed, 650 in lbs of torque, 24v lithium ion battery powered, 1/2" chuck.
  11. SgtRon
    SgtRon Member
    53
    37
    Jun 7, 2017
    Florida
    My lift system is a Goshen, pretty straight forward. Thanks Greyfox for the infomation and linked reference materials.
  12. GreyFox
    1,487
    716
    Oct 10, 2018
    S Ontario
    Respectable torque rating, good low speed rating, has a torque handle [:D] - I presume the hammerdrill function be disabled so it's operating as just a drill? [?]
  13. SgtRon
    SgtRon Member
    53
    37
    Jun 7, 2017
    Florida
    I do have an A/C on the roof and before my heart surgery, I could easily crank it up. I think part of the problem was the drill that I bought was 110vac which uses a brush motor. Tourque was only 416 in lbs, so when the motor slowed to a stop, the brushes fried. My new drill is 24vdc, brushless and 650 in lbs torque. Impact drivers are not recommended, they decrease the life of the lift system.
  14. SgtRon
    SgtRon Member
    53
    37
    Jun 7, 2017
    Florida
    Yes, drill only, no impact.
  15. Sneezer
    1,546
    542
    Orchid likes this.
  16. SgtRon
    SgtRon Member
    53
    37
    Jun 7, 2017
    Florida
    I ended up buying a Kobalt brushless 24v 2-speed drill with 650 in lbs of tourque.
  17. Jameswilson
    Jameswilson New Member
    Oct 23, 2018
    I tried this with my drill. The drill would spin but the drill adapter would not turn
  18. Orchid
    Orchid Sharp Shootin' Grandma
    5,361
    2,081
    May 8, 2011
    Florida by way of WV and MD
    We also have a large pup with an a/c on top. We use the same drill exclusively for this purpose. It's kept in our storage compartment. We always came with hook ups so don't require anything cordless.
    My DH had a heart attack and heart surgery back in 8/17 and this has literally been a lifesaver. I "can" crank up our roof, but I have to take frequent breaks so it would be a long time if I had to do it. With this drill it goes up in minutes and not a bead of sweat.
  19. GreyFox
    1,487
    716
    Oct 10, 2018
    S Ontario
    jnc and Orchid like this.
  20. jnc
    3,928
    1,173
    Oct 1, 2014
    Yup I'm with you there. I modded it Tongue jack also. I made my own drill Jennie to fit the Lift crank,Stabs,Tongue Jack & also a Scissor Jack.
