There has to be a better way.
Discussion in 'Lift Systems' started by beemerboy, May 29, 2013.
  1. beemerboy
    beemerboy New Member
    659
    Feb 13, 2009
    North East Connecticut
    Once again, over the winter mice packed grass in the wiffletree box under my Taos. Once again I had to crawl under the trailer, remove the screws holding the cover on, clean out the grass, re-grease the wiffletree, look for the screws I dropped and put the cover back on.
    There has to be a way to keep the darn mice out. Luckily, no mice have gotten inside the camper.
  2. Twisty
    Twisty New Member
    4,375
    Aug 24, 2008
    Hillsboro, Oregon
    Install a cat in the whiffletree box.
  3. Campit
    Campit EAT SLEEP CAMP
    1,638
    17
    Sep 16, 2011
    I'm glad you're aware of their nesting spot! Just think if you didn't know. That would be a real mess. Would it be practical just to remove the cover during the winter months? Leaving it exposed cause any harm if you did? I agree, there has to be a better way. Aggravating little critters! [:(!]
    Campit
  4. COdreaming
    COdreaming New Member
    344
    Mar 26, 2013
    [LOL] [LOL] [LOL]
  5. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    How are they getting in? Can't you just form some light sheet metal over the openings, drill a few holes and use screws to cover the openings?
  6. Raycfe
    17,005
    2,587
    Maybe some Fresh Cab repellent. we use it inside the PUP during the winter.
  7. daveo1289
    daveo1289 Well-Known Member
    1,009
    129
    Apr 24, 2012
    Rochester NY
    You want to try this stuff. I use it also and seems to do the job.
  8. RockyRoo
    6,592
    224
    Jun 8, 2012
    A more important question, I haven't seen any updates in quite some time, does the fact that you are playing with the Taos mean you are feeling better? I'd been under the impression camping was out of the question till after the transplant(s)
  9. beemerboy
    659
    Feb 13, 2009
    They appear to be getting in around the holes in the frame where the cables go through. I'm thinking of redesigning the cover to make it harder to get in.
  10. beemerboy
    659
    Feb 13, 2009
    I have good days, not so good days and days that are down right crappy. I did an update post last week.
    Right now I feel well enough that I set up my "summer cottage" in my back yard so I can sit outside and use my laptop in comfort. One good thing is I can (and do) is to leave it up all summer unless there is a threat of bad weather.
    As far as really camping (not in my back yard), that's out of the question. It took me over an hour to setup - work a little, rest a lot. And that wasn't a full setup. Once it's setup the work is done until September.
    I can sleep out here all summer, but it's still not camping. [:(]
