Thermostat, Grey-Water Storage Tanks, and Shower Mod
Discussion in 'So, What Did You Do For Your Camper This Month ?' started by Firehawk068, May 18, 2020.
  1. Firehawk068
    Firehawk068 Active Member
    260
    89
    Mar 22, 2016
    Replaced my old mechanical thermostat with a digital one.
    Just two red wires..............One is "Hot", the other goes to the furnace "W"
    The "Hot" wire connects to "R", and the Furnace-trigger wire connects to "W".
    Super Easy!
    This one uses two "AAA" batteries for temp reading, operation, and memory settings.
    Tested and works perfect!
    Added 32-gallons of grey-water storage under the Camper.
    Thread-link here: https://www.popupportal.com/threads/adding-grey-water-storage.129003/
    Also added a bit of usability to the inside shower.
    Main complaints were that the handheld shower hose was too short, and there was no good way to mount it up higher (wife was using a bungee-cord hung from the ceiling).
    Bought a 7-foot shower hose at Home Depot, and now it reaches the ceiling.
    Also bought a 72" Tension-Rod to go from the shower/toilet enclosure to the ceiling, and mounted the hook for the handheld to it.
    Now when you are ready to use it, you just tension it vertically to the ceiling and hang the shower wand on it.
    Did not get any pictures of that mod though. My wife will be happier, and that's what matters most :)
  2. Raycfe
    17,754
    3,248
    Good Job looks great.
  3. Spridle
    Spridle Well-Known Member
    1,250
    420
    Jun 6, 2011
    Nice work.
    ahinson likes this.
  4. Firehawk068
    260
    89
    Mar 22, 2016
    A few pictures of the Shower Mods.
  5. Aladin Sane
    1,145
    170
    Jul 3, 2008
    Iowa
    Not to hijack your thread, but your interior pics look just like a woodgrain version (ours is all white) of our starcraft centennial 3606, but your pics of the underside show a leaf spring axle setup, while ours has a torsion spring axle. I had no idea they made both.
  6. Firehawk068
    260
    89
    Mar 22, 2016
    Ours is the "RT" series, which are pretty beefy frame underneath and lifted axle setup with big 16" wheels/tires.
    I have taken it "Off-road" a few times.
  7. Aladin Sane
    1,145
    170
    Jul 3, 2008
    Iowa
    Ah, that makes sense. Thanks.
  8. Ub3r
    Ub3r New Member
    Feb 22, 2010
    Great mods! I'm jealous of all that clearance. Any worries about the axle hitting the tank under articulation?
