Thermostat Relocation
Discussion in 'A-Frame PopUps' started by Anthony Hitchings, Oct 30, 2019.
  1. Anthony Hitchings
    605
    229
    Mar 2, 2019
    relocated to where we can reach it from bed (at least I can). My field clearance marks have not been erased. Making them was the hardest part of the project.
    shuang2, Econ, NMroamer and 1 other person like this.
  2. bheff
    bheff Well-Known Member
    957
    466
    Feb 24, 2011
    NW Arkansas
    Looks good. Are there any mercury filled thermostats still in existence? Those were very sensitive to being level. The new coil and electronic ones are less sensitive to their orientation.
  3. nineoaks2004
    7,385
    3,143
    Dukes, Fl
    I changed to a digital thermostat about 3 years ago and love the newer unit much better.
    Your re-locate looks very good. Good Luck and Happy camping
  4. Raycfe
    15,411
    1,575
    You should now update it now to a digital thermostat. Works so much better. Not expensive, works better and easier to use
  5. Anthony Hitchings
    605
    229
    Mar 2, 2019
    its not really about digital precision - its about getting some heat before we get out of bed :)
    Econ and bheff like this.
  6. Econ
    Econ Active Member
    467
    185
    Aug 18, 2019
    Deep South
    The Expedition has a different thermostat. It has a on /off switch on top and temperature selection switch lever on bottom. You can reach the on switch from bed if you stretch just a little.
    Good work
  7. Anthony Hitchings
    605
    229
    Mar 2, 2019
    The new location was also intended to get the thermostat out into the fully circulating air - our Low Profile Scout has not such location on the cabinet faces.
  8. Econ
    Econ Active Member
    467
    185
    Aug 18, 2019
    Deep South
    Hey, where you hiding TWO batteries I heard you had????
  9. Anthony Hitchings
    605
    229
    Mar 2, 2019
    one each side - way in the rear, in vented (white) battery boxes under the bed. Right now I am on the lookout for some robust quick clamps to hod the mating halves of the plastic battery boxes together - screws are not ok for monthly maintenance, and the spring clips were not adequate. The "grip" needed for the clamps is about 0.7"
  10. Econ
    Econ Active Member
    467
    185
    Aug 18, 2019
    Deep South
    https://www.amazon.com/Irwin-Tools-...09&hvtargid=aud-801381245258:pla-820574677111
    The ones on the upper right are not operated by springs and the lower right are spring loaded. They are at any big box store. They will clamp onto a 3/4" sheet of plywood with no problem.
    I am concerned about hitting an stud when cutting a hole thru the box wall. How did you avoid them? Do you have an upper and lower vent?
  11. Anthony Hitchings
    605
    229
    Mar 2, 2019
    I have those clamps - too large. I might try the smallest and cut the bars off, but I also have another plan to try out for clamping the battery box halves together..
    There are no intermediate studs in the walls that I am aware of - just the foam core, there might be a wood band around the edge for screws to bit into. (FWIW - the old style panels were made up as a full sheet by running the ply-foam-aluminum sandwich thru the laminator - its in their 4-part video series
  12. Anthony Hitchings
    605
    229
    Mar 2, 2019
    Lower vent is in the base of the as-supplied battery box. In the case of my one battery that had a cell punctured by a too-high screw head, the acid drained out the bottom vent of rusted up the nearest stabilizer (which I am currently de-rusting after removing it from the trailer).
    I anm replacing all battery mounting screws with flat-head screws.
  13. Anthony Hitchings
    605
    229
    Mar 2, 2019
    Update on the thermostat relocation - its worked out great :)
    Snow likes this.
  14. Anthony Hitchings
    605
    229
    Mar 2, 2019
    Guess What - we are replacing the miserable Atwood thermostat with an electronic thermostat. The - on-off switch on the Atwood is just too terrible a design (even after I fixed it, sort of, with a Dremel).
  15. shuang2
    shuang2 Well-Known Member
    1,185
    93
    Apr 20, 2010
    Where to buy the digital thermostat?
  16. Anthony Hitchings
    605
    229
    Mar 2, 2019
    Huh - where else - Amazon !!
    look for this:
    LuxPRO PSD010BF Heating Only with Fan Digital Thermostat
    by LUXPRO
    Its about $30.
    It did not feel like futzing with a cheapie item when it was not necessary. This fan is fit for purpose and is easy to read and turn on and off.
    I will install it after the the Aliner warms up from sunshine and the day brightens up. Its clear and cold here in Oakland, CA. (38.4 deg F)
  17. Anthony Hitchings
    605
    229
    Mar 2, 2019
    Econ and Raycfe like this.
  18. Anthony Hitchings
    605
    229
    Mar 2, 2019
    so here is a pic of the installed LUXPRO thermostat
  19. Econ
    Econ Active Member
    467
    185
    Aug 18, 2019
    Deep South
  20. Anthony Hitchings
    605
    229
    Mar 2, 2019
    I did same thing with Dremel, but at the end of the day, it failed to meet my needs.
