Thetford 402C Cassette Toilet Problems
Discussion in 'Port-A-Potties / Cassette Toilets / Bath Houses' started by Cabello Rojo, Sep 6, 2019.
  1. Cabello Rojo
    Cabello Rojo New Member
    Sep 6, 2019
    [CC]Hi! I'm new to this site and to PUP camping. We've tent camped for years but finally decided to get off the ground. We recently purchased a used 2007 Fleetwood E2 which has needed more repairs than I thought when we purchased it. Our biggest problem so far is the Thetford 402C LH cassette toilet is broken. It has never flushed so we've just used the shower to add water to the bowl until I could repair it. The mechanical closure mechanism broke and pieces fell into the tank this past weekend. I tried to recover them when I dumped but obviously missed something; no big deal. I purchased a new replacement mechanism, water pump and control board online. I have repaired the closure and it works fine. I replaced the control panel but do not have power to the pump. I have 12v to the board and have removed the pump and jumped it and it runs fine. I don't believe the board is bad.
    Are there any interlocks that have to be met to allow the pump to come on with the switch?
    Flush water level shows @75% full and the holding tank is empty, also the "E" fuse underneath is not blown (but I replaced it anyway).
    I'm kinda out of ideas.
    Hope I'm posting this in the correct location..thanks
  2. Sjm9911
    9,105
    6,493
    I have an older hand pump one, on mine the hose was disconected and filled with gunk from not being used. Also the tank had to be flushed, it had all sorts of stuff in there that cloged the hose.
    Yours has a circuit board? Wouldn't just an on off switch be good enough? I relly really can't think of why a board is needed.
  3. Cabello Rojo
    Sep 6, 2019
    It's a shower and toilet in one unit. The board controls the electric pump and "full tank" indicator and makes the unit waterproof. An enclosed, spring loaded rocker switch is a final option.
  4. Sjm9911
    9,105
    6,493
    Ah, mine just has a float that never worked and an indicator level, lol. I would have to guess , if the pump works while jumped, and the power is going to the board, it would have to be a bad board. The pump dosent run at all when conected to the board ,right? No way for anything to be clogged in the lines?
  5. SteveP
    2,092
    807
    Mine has a 5 amp fuse where the factory oem wiring connects to the cassette wiring. Its almost hidden, on the non-hinge side when the access door is open, between the camper wall and the cassette. Then there's the 3 amp fuse in the blade switch, on the left wall of the cassette tunnel. If either of those is bad there's no power to the pump.
  6. Cabello Rojo
    Sep 6, 2019
    OOOhhh...I looked for any other fuses but haven't found anything except the 3 amp mounted to, what I believe is, the high level indicator (magnet sensor) on the inside upper wall.
    I have 12.7v to the board and also on the board connectors from the plug. There's a blue and brown wire(s) running to the pump and I show 12.3v if I keep my meter red on board red and alternate my black meter to either the blue or brown to the pump.
    Is there some sort of interlock to keep from running the pump if, say, the waste tank was removed? I see nothing that would prevent this unless the thing I believe is the high tank level switch is it and it's bad? IDK
    I'm going to go check for another fuse somewhere.
  7. Cabello Rojo
    Sep 6, 2019
    I couldn't find any other fuses except the 3amp mounted high underneath. I removed this fuse and I loose all power to the plug/board.
    It sure acts like a bad board. I'm going to call Thetford again.
  8. SteveP
    2,092
    807
    That is the blade switch. I don't know its function but I don't think it has anything to do with cassette level. I have no indicator but I still have the switch. If the 3 amp fuse is pulled the pump will not run. If the pump locks up the fuse will blow. Your thought that it may prevent the pump from running when the cassette is pulled may be correct.
  9. BillyMc
    BillyMc Well-Known Member
    2,045
    1,382
    Mar 25, 2018
    Ours didn't work when we bought it. It still doesn't work, but I haven't messed with it yet. We too just use the shower for water. The shower wand is an easy work around. I'll get around to checking it one day, but for now finishing solar setup trumps toilet pump.
  10. HappyTraveler
    HappyTraveler Well-Known Member
    547
    464
    Apr 30, 2019
    New York
    Seeing posts like this makes me glad our toilet is such a simple set-up. :)
  11. Sotovoce
    Sotovoce Active Member
    264
    145
    Jun 27, 2015
    Georgia
    Ditto, HappyTraveler!
  12. Thorofin
    Thorofin New Member
    26
    May 27, 2020
    Tampa, FL
    Was there ever a solution to this issue?
