Thetford C-402C Fuse Location
Discussion in 'Port-A-Potties / Cassette Toilets / Bath Houses' started by hpka, Jun 30, 2020.
Tags:
  1. hpka
    hpka New Member
    Aug 26, 2019
    Please let me be clear, I've Googled this, searched here and read some results, looked in the manual, looked at multiple YouTube videos (here's one), checked Google Images and I'm still stuck.
    I have a Thetford C-402C toilet installed in my 2011 Rockwood Freedom 2280BH. Here are some photos of the tank slot/cavity/locker.
    For the life of me, I cannot see or find the fuse that I know to be included on these. Many have said it's on the left side of the wall (nothing) or the roof of the slot (if it's there I can't see it).
    In my specific case, can anyone point it out to me? Bonus points if someone takes one of those images an applies a helpful red arrow.
    Thanks
    Thorofin likes this.
  2. Sjm9911
    9,105
    6,493
    Look inside the pup, look for an acess hatch or door. Some dont open easy and theee a pita to get at. Mine was a pump model, so im going off memory of what i read.
  3. hpka
    hpka New Member
    Aug 26, 2019
    From this diagram it could be located about 2/3 of the way into the slot (right beside the waste outlet from above, gloves required then). When I can get down to the camper again I'll check, but does this sound familiar to anyone?
  4. Sjm9911
    9,105
    6,493
  5. Sjm9911
    9,105
    6,493
  6. SteveP
    2,092
    807
    If you go back to HPKA's diagram, the "Reed switch housing," #30, appears to be missing from your cassette tunnel. The fuse mounts into the reed switch housing.
  7. Thorofin
    Thorofin New Member
    26
    May 27, 2020
    Tampa, FL
    I have no idea where the fuse is, but the pictures were super helpful. I'm reassembling one of these in my Aliner's Wet Bath, and there were a couple of parts I wasn't sure about.
  8. hpka
    hpka New Member
    Aug 26, 2019
    I'm not sure but that housing might be here. I don't have a clearer photo at the moment but the shape appears to match from what I can see. Will check next chance I get.
    Getting hopeful I can find it!
  9. SteveP
    2,092
    807
    Blew up the pic and that looks right. See if you can pry that small panel out, the fuse should be on the backside.
  10. hpka
    hpka New Member
    Aug 26, 2019
    Went down last night and found it where we thought it was. It wasn't necessary to remove the panel, I just reached in with a gloved hand and found a standard 3amp ATO blade fuse. Put a new one in there to replace the blown one, will test it this weekend.
    Here's an annotated image for anyone else looking
  11. Anthony Hitchings
    2,279
    1,248
    Mar 2, 2019
    Oakland, California
    in the photo - which way is UP ?
  12. hpka
    hpka New Member
    Aug 26, 2019
    Top of photo is up
  13. ShaneSD
    ShaneSD New Member
    Nov 8, 2020
    Thanks for completing the thread by posting up the success story photo. I was looking through the manual and the assembly drawings and they are useless. This pic is exactly what I needed.
    Was the fuse blown when you pulled it out? Did swapping it fix the issue?
