2006 Fleetwood E2.
From what I've gathered I have the C4 potty. Also the previous owner put blue chemical in the fresh water tank. Everything still seems to work but I will be flushing out the fresh water tank asap.
When I first pulled things apart the "blade" (Round black disk that "closes" the tank), as it seems to be referred, to as had fallen off and was in the bottom of the cassette. So, when it was in the closed position I just would see the arm with the hole in it. I fished the blade out and put it back into what appeared to be the proper position. It seems to work fine but there's really no sealing action by the blade. i.e. if I flush it with the blade closed the water still goes past it into the tank. Should there be a better seal there? There is the rubber seal that seals the potty to the tank but I was thinking that the blade should probably seal up better to keep odors in.
I found a parts diagram for the toilet but it doesn't cover the blade itself inside the cassette. Am I missing a gasket or something?
Thanks,
Jeff
Thanks,
Jeff
