Thetford cassette toilet not wired
Discussion in 'Port-A-Potties / Cassette Toilets / Bath Houses' started by Rosebud Motel, Jun 25, 2020.
  1. Rosebud Motel
    Rosebud Motel New Member
    19
    27
    Jun 25, 2020
    Missoula, MT
    So I'm guessing these loose wires are why my thetford cassette toilet doesn't flush. Can anyone help me learn where to run those wires to power? Just bought this '08 Starcraft 2406. Previous owner says he never used the toilet. Any ideas would be much appreciated. thx! thetford.jpg
  2. GreyFox
    GreyFox Well-Known Member
    2,362
    1,208
    Oct 10, 2018
    S Ontario
    Anywhere you can conveniently pick up + - 12 vdc.
    Rosebud Motel likes this.
  3. Rosebud Motel
    19
    27
    Jun 25, 2020
    Missoula, MT
    Indeed. I was hoping someone might know where that is on a pop up such as this.
    Orchid likes this.
  4. GreyFox
    2,362
    1,208
    Oct 10, 2018
    S Ontario
    I'd be inclined to pick up the +/- 12 vdc where it feeds the fridge as you'd never be running the fridge on 12 vdc anytime you're camping and would want to use the cassette toilet. In the case of your Starcraft 2406 the fridge is on the opposite side from the toilet but you could run the toilet wires down through the floor, along the underside of the trailer floor, and back up to the rear of the fridge where you'd tap into the +/- 12 vdc. I did exactly this when I installed a car stereo in our Santa Fe and needed +/- 12vdc to power it.
  5. Raycfe
    17,005
    2,577
    The wiring for your toilet will be red is the power wire (+) and the black is the negative (-) ........ Now this may sound odd, but you will connect the red wire to a black 12 powered wire of the camper and the black toilet wire to a white camper ground wiring. When you get all done and your toilet works .....mark the toilet wires (+) and (-) ............ if it was me I would cut off as much of the wrong color wires as I could.
  6. Orchid
    Orchid Sharp Shootin' Grandma
    5,766
    2,617
    May 8, 2011
    Florida by way of WV and MD
    It looks like there is some white wire right there, under the gloves.
    Rosebud Motel, Sjm9911 and Raycfe like this.
  7. Rosebud Motel
    19
    27
    Jun 25, 2020
    Missoula, MT
    Oh, you mean this white wire? Bear with me, I'm new at this. Is this a 12V I can splice into?
  8. Rosebud Motel
    19
    27
    Jun 25, 2020
    Missoula, MT
    Thanks for the info! It's always nice to think I might do it correctly the first time if I ask enough questions.
  9. Rosebud Motel
    19
    27
    Jun 25, 2020
    Missoula, MT
    Thanks GreyFox! That sounds a little tricky, but is a great idea. I might try that.
  10. GreyFox
    2,362
    1,208
    Oct 10, 2018
    S Ontario
    Yikes - NO! That white wire is 120 vac Romex, not 12 vdc! [:O]
    Orchid and Rosebud Motel like this.
  11. Rosebud Motel
    19
    27
    Jun 25, 2020
    Missoula, MT
    Ha, don't worry, I'm not rushing into anything. Thanks again!
    Orchid likes this.
  12. GreyFox
    2,362
    1,208
    Oct 10, 2018
    S Ontario
    A few years ago I installed an inverter in our travel trailer's front pass through cargo compartment and wired it's 120 vac output to duplex receptacles on each side of the bed and one at the galley. To get to the galley area I ran the cable along the underside of the trailer floor so I enclosed it in protective tubing.
    However you can also buy less costly convoluted split loom tubing that's made to keep wires together and protect them from abrasion. :)
  13. Sjm9911
    6,954
    4,339
    Just a thought, where do those wires go? You did confirm that they come from the pump right? If not they might be the power wires.
  14. Rosebud Motel
    19
    27
    Jun 25, 2020
    Missoula, MT
    I don't know what the wires are. Sorry, no confirmation of anything. They seem to run the length of the toilet frame that is visible from the outside access hatch.
  15. Sjm9911
    6,954
    4,339
    Those might be your power wires coming in. You need to remove the pump from the tolet and then see if it works. I think someone probably removed the pump and left the wires in anticipation of replacing it? Maybe anyway. Who knows. Mine had a hand pump, lol.
    HappyTraveler and Rosebud Motel like this.
  16. Rosebud Motel
    19
    27
    Jun 25, 2020
    Missoula, MT
    Ok, thanks for the help! I’ll have to dig deeper into toilet world
  17. Sjm9911
    6,954
    4,339
    Grey fox might be able to post the scamatics for you.
  18. Orchid
    5,766
    2,617
    May 8, 2011
    Oh my, no! That's much bigger than it looked in the first photo. :shocked: Yikes! I don't know what it is, but definitely not what you're looking for.
    Our cassette toilet is manual flush, so I have no idea what what kind of wires are behind the electric flush models. If I had electric flush, I would sure go out and poke around for you.
  19. Raycfe
    17,005
    2,577
    Orchid should we start calling you "Sparky" LOL
  20. Rosebud Motel
    19
    27
    Jun 25, 2020
    Missoula, MT
    I don’t want anyone to go poking around their toilets on my behalf, lol
