Thetford cassette toilet not wired
Discussion in 'Port-A-Potties / Cassette Toilets / Bath Houses' started by Rosebud Motel, Jun 25, 2020.
  1. GreyFox
    GreyFox Well-Known Member
    2,435
    1,260
    Oct 10, 2018
    S Ontario
    Considering the OP's camper is a 2008 the powered cassette toilet it has is likely a Thetford C402 rather than an older C2 or C3. To establish just what these 2 wires are for my first step would be to put a voltmeter (in the DCV mode) across them to establish whether there is +/- 12 vdc and whether this voltage is always there or intermittently. If there is no voltage at all, under any circumstances, then considering the location they are likely wires connected to the toilet motor.
    Rosebud Motel and Sjm9911 like this.
  2. HappyTraveler
    HappyTraveler Well-Known Member
    515
    396
    Apr 30, 2019
    New York
    Been following this thread and have to say, crappers should not be this much trouble.
    Thankful for my simple, nonelectric hand pump/flush model.
    Good luck Rosebud and really hope you can get it working.
  3. SteveP
    SteveP Well-Known Member
    1,748
    541
    Is the outside light on the left side of the door as you enter the camper. If so, you should be able to access it's wiring through the cabinet behind the cassette.
  4. Rosebud Motel
    Rosebud Motel Member
    19
    29
    Jun 25, 2020
    Missoula, MT
    Thanks! Of course we can always just pour water down the thing, but it would be nice if it functioned as intended once in it's life.
    HappyTraveler likes this.
  5. Rosebud Motel
    19
    29
    Jun 25, 2020
    Missoula, MT
    Yes, the light is on the left of the door. I'll look into that idea, thanks!
  6. Rosebud Motel
    19
    29
    Jun 25, 2020
    Missoula, MT
    Thanks again GF. I'll dig out the multimeter and give it a whirl.
  7. Anthony Hitchings
    1,559
    807
    Mar 2, 2019
    99.9999999% the red and black wires are to the pump. Just put 12V to them briefly and listen for the whir of a pump motor. Then its confirmed.
    Rosebud Motel likes this.
  8. Rosebud Motel
    19
    29
    Jun 25, 2020
    Missoula, MT
    Turns out there are black and red wires behind that outside light that had been cut. It's pretty clear now that these used to run to the toilet motor. Upon reattaching the toilet motor wires to those in the cabinet, I get no motor noise or function. I also connected the toilet wires directly to my battery to no avail. Motor must be dead. Sad face.
    Thanks again for all the helpful suggestions!
  9. GreyFox
    2,435
    1,260
    Oct 10, 2018
    S Ontario
    I seem to recall there's a fuse in the positive wire feeding the pump - have you checked it? [?:~{]
  10. Rosebud Motel
    19
    29
    Jun 25, 2020
    Missoula, MT
    I have checked it and it looks brand new. I also pulled up the water pump and tried to manually rotate the little impeller in case it was stuck. Still no movement. Probably time for a new pump.
