Time to quit ignoring my propane
Discussion in 'Propane - Got Gas' started by Orchid, Oct 4, 2016.
  1. Orchid
    Orchid Sharp Shootin' Grandma
    5,819
    2,732
    May 8, 2011
    Florida by way of WV and MD
    Thank you VERY MUCH! :) I very much appreciate the time you spent looking into this for me. This is exactly what I was looking for. I tried to find it myself, quite a few times before I posted this thread. But even had I found it, an explanation like you give here is much more helpful!
  2. rabird
    7,621
    739
    N. TX
    I might suggest a horizontal 2 stage RV regulator. like
    https://www.amazon.com/Camco-59333-Horizontal-Propane-Regulator/dp/B0024E6TX2
    It uses the POL left hand connection, no ACME excess flow feature, put the 90 on the end and your cooking with gas!
    My understanding is the ACME is not strong enough to use with a 2 stage reg but I did it with my '96 coachman. I changed out the POL for a black ACME - no wrench needed!
    This would make the high pressure outside stove useless as it is now.
    Finding a 16 psi or 15 psi regulator may be an issue
  3. Sonshine
    Sonshine Member
    235
    Aug 20, 2012
    Propane101.com is a great resource to help understand propane. It is written in simple terms and is easy to understand. This deals mostly with home applications but alot of the info is applicable to RVs as well.
  4. nineoaks2004
    8,244
    3,711
    Dukes, Fl
    X2 I do believe a 2 stage regulator is the standard on all RV's and has been for quite a while ow.. The first stage has high pressure then the 2nd stage reduces the gas to 11" wc (water column) your stove should have a regulator as it only requires 6" WC 11" would make the flame way to hot and probably too high. The regulator should be mounted so the vent is pointed down to keep water, debris etc. out and a cover should always be use to protect the regulator. Single stage regulators are usually used for gas grills etc.
  5. Orchid
    5,819
    2,732
    May 8, 2011
    Thank you, I will check it out.
    That's what I have read in other places as well. At least I know I wasn't imagining things.
