Tire and wheel preferences / where ?
Discussion in 'On The Road' started by dviking, May 29, 2017.
  1. Muller 5
    Muller 5 Active Member
    350
    175
    Jan 6, 2019
    STL
    She said that's what is currently on the trailer. If it's currently on there, then I'm sure she has 5 lug wheels and enough room. Please don't treat women like idiots because we ask questions.
  2. mpking
    mpking Well-Known Member
    1,460
    433
    Jun 17, 2014
    Raynham, MA
    I had that size tire once.
    I believe (and google seems to confirm) that it's new size is 205/65 r10
  3. mpking
    1,460
    433
    Jun 17, 2014
    Raynham, MA
  4. Adam H
    Adam H Active Member
    549
    227
    Aug 22, 2015
    Who the F&@K are you and where did you pull that out of? Unless I read her post wrong, she had a 10" wheel and her link was for a 13" wheel. One of my previous campers has a 10" wheel and it was 4 lug, that's why I asked. If I mis-read her post, it was exactly that. Not sure where you came to the conclusion I was being degrading to women....
    eoleson1 likes this.
  5. VDerks
    VDerks New Member
    Jan 9, 2019
    It does have 5 lug wheels. How can I tell if there is enough room?
  6. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    On a related note - for all of you that buy entirely new wheels (rim+tire) on line - how do you dispose of the old wheels?
  7. Snow
    11,801
    2,380
    I used my old sets as winter storage tires..
    Jason0405 likes this.
  8. Sjm9911
    10,632
    8,018
    Check your town if they have a dump. Everywhere over here they recycle the tires and the rims go into the metal pile. You just need to seperate them.
  9. Muller 5
    350
    175
    Jan 6, 2019
    STL
    My apologies, I went back and re-read. The numbers were different. I didn't notice at first. I have been condescended to so many times on here that I jumped to conclusions.
    Bigantlers likes this.
  10. SpaceGuy85
    SpaceGuy85 New Member
    27
    May 1, 2019
    League City Texas
    Mine are Loadstar ST 185 80 R13 Radials on my PUP. Great tires, and track better than bias ply..
  11. SteveP
    2,257
    931
    According to eTrailer the closest equivalent to your current tire has an outer diameter of 20.4 inches.
    https://www.etrailer.com/Tires-and-Wheels/Kenda/AM3H480.html
    The ST175/80D13 has an outer diameter of 24 inches.
    https://www.etrailer.com/Tires-and-Wheels/Kenda/AM3S030.html
    So the 13 would be 3.6/2 = 1.8 inches taller from the axle to the top of the wheel well. You probably need at least 2.5 inches for spring travel so I would say that you need at least 4.5 inches from the top of your current wheel to the top of the wheel well to change to the 13" wheel.
    There's nothing wrong with using the 10 inch wheel as long as the tire load capacity is sufficient for your pup.
  12. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    most importantly, make sure that your spare tire/wheel matches whatever you put on the axle.
  13. SpikeMike
    SpikeMike New Member
    Jun 19, 2018
    Tampa, Florida
    Exactly! Aside from that, you may want to avail high-quality wheels and tires, a combination that would last for a very long time. I usually purchase mine from 4WheelOnline, since their prices are fair and reasonable.
  14. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    "Fair and reasonable" - a phrase much used by bureaucracy in contractual matter!
  15. Jgiattino
    Jgiattino New Member
    May 10, 2021
    Hello all. I have a 97 Coleman Sea Pine. Just curious the original specs say the tire is 5.30x12 but i bought it with 175/80 d13 on it. They are okd and need replacing and i think im going to go with the Carlise 175/80 d13 radials. Slight size increase in diameter from original specs but shouldn't be an issue right? Bolt pattern works. Any thought.
  16. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    It will be fine.
    As a caution - check inside both wheel wells - if no sign of the old radial tires rubbing the wheel wells, then you are "Good to Go"
    I might eventually make the same change from 12's to13's, as my recent measurements and gage checks indicate that I would have clearance.
