Tire blowouts
Discussion in 'On The Road' started by Harrisds9880, Apr 18, 2017.
  1. Snow
    11,801
    2,380
    Or it was because the date code was 2015.. puts it nearly a 5yr old tire..
  2. Econ
    Econ Well-Known Member
    1,485
    914
    Aug 18, 2019
    Deep South
    We will never know the cause. Are you saying this tire was 4.5 years old and only been exercised twice?
    A tire person told me the difference in car tires and trailer tires was car tires got exercised more frequently.
  3. SpaceGuy85
    SpaceGuy85 New Member
    27
    May 1, 2019
    League City Texas
    Look at the sidewalls of your tires for max pressure. That is how much they should be inflated. I doubt 48 PSI is the max. Low tire pressure can cause what we all call the China Bomb syndrome. I have a 2018 Coachman Clippper 125 ST sport Had a blowout on the door side, and, yes the tire pressure was at 65psi per the max pressure. What I found in my case was that the tires were manufactured in 2015, and put on this new 2018 camper at the factory. Forest River is getting the parts to fix it, but, really, even if you do everything right, you can still have issues. Not sure what tires you have, but, you should have D Rated tires for the load of the HW. My tires are ST 185 80 R13's made by Kenda (Loadstar). Best of luck to you, and I have been told this just happens.... As for me, makes me not want to do this anymore. My parents had a 1963 Gator 1200, that my Dad only change the tires 2 times in 20 years. Not sure what tires they were, but, he was always checking tire pressure, etc.... Guess they were American made tires.... Happy Camping!
  4. SpaceGuy85
    27
    May 1, 2019
    League City Texas
    Yep, you are probably correct, but, I think it was because the tires were almost 4 years old when the camper was built. But, now, Forest River is going to provide 3 new tires with wheels, and fix all of the damage. Probably will be a scary ride the first few times after the repair. Happy Camping to All!
  5. tombiasi
    6,639
    2,209
    I give 2 to 1 you had them under inflated.
    Snow and xxxapache like this.
  6. Sjm9911
    10,639
    8,024
    If i were to guess tou hit a pot hole or something that bent the rim underinflating the tire. Thats easy to not notice. Then after driving a bit , bam. Flat. The tire heats up faster due to the less air and rides a bit on its sidwall. Total tire failure. There is a sizable ding in the rim in your first picture. I cant see any other way for that to get there uless tou hit a curb or something after the flat. And yes, it happens all the time, and sometimes its not our fault. You could be the most meticulous driver and it can easily still happen. Hope you get it all fixed up and dont let it discurage you. Just bad luck is all.
    Anthony Hitchings likes this.
  7. Jack Sprat
    Jack Sprat Active Member
    184
    82
    Aug 31, 2019
    NC
    I would suspect bearings.
  8. WrkrBee
    WrkrBee Un-Supported Member
    6,543
    3,448
    ??? Why?
  9. Jack Sprat
    184
    82
    Aug 31, 2019
    NC
    Bearing over heated disentegrated which over heated wheel. Which melted tire bead. Pow went tire on boat trailer. Had spare, that got us off I-26. Had to buy new new bearing and bearing cup, grease seal, as well as dress the axle with Emery cloth.
  10. WrkrBee
    6,543
    3,448
    Thanks for clarifying. It can happen. Sure they can fail quick, but not normally. Boat bearings have a harder life than camper bearings. But bearings had been checked.
    Per SpaceGuy85- Whenever I stop for gas or other breaks, I inspect the tires, touching the rubber, and the hubs to see if they are warm. There was no indication of any issues prior to the blowout (at only 40mph)
  11. Jack Sprat
    184
    82
    Aug 31, 2019
    NC
    Ok
  12. Sjm9911
    10,639
    8,024
    A bad or unlubricated berring will not be good for the tire. But it will not put a big dent in the rim.
  13. Anthony Hitchings
    3,054
    1,808
    Mar 2, 2019
    Oakland, California
    Don't overthink the cause; sometimes "s..t" happens.
    xxxapache likes this.
  14. SpaceGuy85
    27
    May 1, 2019
    League City Texas
    Nope, per the side of the Tire, 65 PSI Max, which they were. Again, appreciate all of the input, but, I think we just had old tires... Why Forest River did that, I will never know.
  15. SpaceGuy85
    27
    May 1, 2019
    League City Texas
    Nope, 65psi, and max speed running down the road was 65mph. Very carefully followed what my dealer told me to do. Again, Forest River seems to agree that the tires were old. I am thinking there is something else going on here.... We will see. Man, give me my parents old 1963 Gator 1200 popup. My dad was cheap, and used the same tires for over 10 years. Guess they did make things better back in the good old days!
  16. tombiasi
    6,639
    2,209
    OK, The tires spec 65 PSI?
  17. AndreD
    AndreD Active Member
    102
    47
    Jul 24, 2020
    Great White North
    Does this stuff happen often? These responses make it seem like it’s just part of camping with pop ups.
    I just bought a new rockwood 1940ltd and am seriously starting to reconsider whether this was the right idea. I am starting to think I should have just stuck with tents.
    mmpopuplvr likes this.
  18. xxxapache
    4,089
    2,373
    Sometimes it just happens. You can have tires that are "in date", are properly inflated, have a TPMS, and not driving too fast for the tire and....Boom!....Happened to me last fall.
  19. Anthony Hitchings
    3,054
    1,808
    Mar 2, 2019
    Oakland, California
    Blow outs are not common, but they do occur. Web forums amplify the frequency of such events.
    mmpopuplvr and AndreD like this.
  20. AndreD
    102
    47
    Jul 24, 2020
    Great White North
    that’s very reassuring to hear. I was starting to really regret having put a deposit on a unit. I tent camped for years without issue.
