Tire protection
Discussion in 'Tires / Brakes / Bearings / Axles' started by Miamama1, Nov 15, 2020.
  1. Miamama1
    Miamama1 New Member
    26
    Jan 23, 2020
    Tx
    Hello all.
    What is the best product for TIRE PROTECTION; to prevent dry rot?
    Any suggestions?
  2. BikeNFish
    BikeNFish Well-Known Member
    4,158
    3,142
    Apr 24, 2017
    Maplewood, MN
    Keep them off the bare ground and covered.
    poppy65 and rescamilla like this.
  3. RVAdebla
    RVAdebla New Member
    Oct 25, 2020
    Does silicone spray or armor all seem to help at all? Or just that does make them look shiny?
  4. Ladiesman
    Ladiesman Well-Known Member
    758
    541
    Feb 6, 2018
    When looking for tire protectant look for water based. You will have to reapply more often because it will wash off but compared to the petroleum based stuff it actually is a protectant and not just to make them shine. Formula 303 tire balm is a good product.
    rescamilla and Miamama1 like this.
  5. xxxapache
    4,119
    2,430
    Keeping them covered is the best advice.
    Miamama1 and Rik Peery like this.
  6. Anthony Hitchings
    3,168
    1,883
    Mar 2, 2019
    Oakland, California
    I am in the "waste of time" camp, you will (or should) wear them out before they come close to rotting out. But for sure to keep an eye on them (visual inspection).
  7. xxxapache
    4,119
    2,430
    Many people will never tow a trailer enough miles to wear the tread out. I know I have never worn the tread off.
    Toedtoes, kcsa75 and Miamama1 like this.
  8. Sjm9911
    10,783
    8,165
    Im in the replace them every 6 year camp. So i don't do anything. Just not worth it for me.
    rescamilla, kcsa75, Westcoast and 4 others like this.
  9. xxxapache
    4,119
    2,430
    I had two blowouts this summer on two different trailers. One tire was 15 years old. I guess I may have deserved that one due to age. The other tire was 5 years old. That trailer had TPMS. I had just stopped and checked the temps 20 miles prior, too. It just went BOOM!
  10. Sjm9911
    10,783
    8,165
    Its so easy to pick up a nail and loose pressure, the tpms probably cant register it fast enough, heat builds up and boom. It happens, it sucks and i homestly cant worry about it!
  11. generok
    3,358
    2,150
    Feb 7, 2013
    Anchorage, AK
    Any tire shine product is mostly cosmetic and does nothing to protect the tire. Some petroleum based products can even hasten UV exposure damage. Just keep them clean, and cover them when you can, and replace every five years or so and you will be just fine.
    Miamama1 likes this.
  12. xxxapache
    4,119
    2,430
    I believe my system will register fast enough. I have the Ford system that is integrated into the truck. I don't see the point in TPMS if it doesnt work fast enough to let you know of low pressure when it happens.
    I dont think I picked up a nail and lost pressure that quickly considering the tires were fine at the stop 20 miles prior.
    I dont particularly worry about a blowout, but do what I can to try and prevent if on my TT due to the amount of damage it can cause and the logistics of getting it repaired if I need to farm the work out.
  13. Sjm9911
    10,783
    8,165
    On my truck ( chevy) and jeep it took 20 to 30 minutes of driving to reset the tmps in the tires after i changed them. So, while i always thought it was instant, i dont now. Yours could be diffent.
  14. xxxapache
    4,119
    2,430
    To set mine up on the trailer, you start letting air out and the truck honks the horn when it detects air loss. It usually honks the horn within about 30 seconds.
    When I have to adjust trailer tire pressure, I sometimes use the display on the trucks dash instead of a gauge. It registers changes immediately.
  15. Miamama1
    Miamama1 New Member
    26
    Jan 23, 2020
    Tx
    I was actually looking into tire covers as well.
    It is parked in the driveway, but i have no way of getting it off the ground...?
  16. Miamama1
    Miamama1 New Member
    26
    Jan 23, 2020
    Tx
    I saw the 303 product at Walmart yesterday and thought I'd check here before I invested in any product.
    Thanks!
  17. Miamama1
    Miamama1 New Member
    26
    Jan 23, 2020
    Tx
    Wow, this is a wonderfully responsive group!
    Thank you for all your suggestions!
    I think I will get the 303 and wheel covers and just plan on changing them every couple of years.
    Which brings me to my next question:
    How often should I replace my tires?
    My pop-up sits in the driveway under a large tree and only one tire is actually exposed to the sun.
    Discount tire advised changing tires every 3 years.
    I also bought a spare.
    Suggestions on replacement frequency?
  18. BikeNFish
    4,158
    3,142
    Apr 24, 2017
    Maplewood, MN
    Then use a couple of pavers or boards.
  19. tenttrailer
    3,745
    645
    Jul 18, 2013
    Thornville, OH
    I always replaced trailer tires because they failed or timed out. Never because of dry rot or were worn out. We put between 6k to 10k miles a year on our tires.
    rescamilla likes this.
  20. jmkay1
    7,059
    4,116
    . You can drive the tires on lynx blocks that's what they mean by getting them off the ground. It's dirt/mud/grass you don't want sitting on the tires when it sits. If it's on a paved driveway then your ok there.
