Tire Replacement Time
Discussion in 'Tires / Brakes / Bearings / Axles' started by David Branley, Oct 2, 2019.
  1. David Branley
    David Branley Member
    54
    Jul 31, 2018
    Hi All,
    Looking for a little guidance on tire replacement. I have a 2007 Fleetwood sun valley.
    Trailer currently has st175 80 d13 tire rates for 1610 lbs.
    GVWR for the trailer is 3500 lbs
    GAWR for the trailer is 3320 lbs
    I assume the difference is to accommodate for the tire rating, ie 1610 x 2 = 3320.
    Oddly enough the brochure for that year and model indicate a tire size of st185 80 d13, I cant really account for why this trailer is different to the brochure spec.
    I guess the ideal Goal would be to find a new tire, ideally a tire wheel combo that can handle a load closed to GVWR / 2 or 1750 lbs is the same size but not having much luck with that.
    Any advice or guidance appreciated,
    Thanks for your help,
    David
  2. Snow
    10,964
    1,620
    Kenda makes a st185 80 13D tire that will do..
  3. David Branley
    54
    Jul 31, 2018
    Thanks for the pointer, do you see any issue in moving up from a 175 to 185? Even though the model brochure states 185 for my trailer the sticker on the side of the trailer indicates a 175 / 80 / D13
    One option I am looking at is purchasing couple of new wheels from etrailer https://www.etrailer.com/p-AM22323HWT.html
    and bringing them to America Tire for install of a couple of Carlisle Radial Trail HD ST185 /80 R13 Load Range D
    This would be good for 1710lbs *2 = 3420 lbs giving me some more headroom on my weight.
  4. jmkay1
    5,788
    2,601
    My guess is the prior owner just put on any tire they could find that was close not realizing it's under rated. When I purchased my camper I discovered I had a load range C tires on when I should have had the load range D exactly what your camper requires. In Talking with the tire shop apparently they keep the C range in stock but they had to special order the D range.
  5. Sjm9911
    7,388
    4,775
    Check wall mart also. I had a weird size they had them through a 3rd party mounted and free shipping.
    wmgeorge likes this.
