Tire speed
Discussion in 'Tires / Brakes / Bearings / Axles' started by Kevin79, Sep 15, 2016.
  1. Kevin79
    Kevin79 Member
    110
    Jul 3, 2016
    Michigan
    How do I tell the max speed that my tires are rated for?
  2. Arlyn Aronson
    Arlyn Aronson Well-Known Member
    1,043
    506
    Jun 11, 2014
    Houghton, MI
    If they explode, that was to fast. [:D] If they're in reasonable shape (no cracks) and air in them, I'd not worry about them to much. When we travel to my home state, we tootle right along at 80mph which is the interstate limit.. I've never bothered to look at our tires for there MAX speed.
  3. tenttrailer
    3,118
    277
    Jul 18, 2013
    Thornville, OH
    Most trailer tires "ST" are ratted at 65 mph max. Most trailer drivers drive at 65 mph. I think there are times most drivers will exceed the ratting, but its not the norm.
  4. tombiasi
    5,149
    877
  5. kitphantom
    11,615
    773
    It does seem that most are rated at 65 mph. I actually called Kenda to check the rating on one set on our pup.
    Truth to tell, we usually cruise at about 67 mph; we did that with our pups and now TT. Having experienced both the entire wheel flying off (the lug nuts did not get re-torqued after tire rotation, lesson learned) and a blow-out on the first pup, I'll try to skip doing either again. That one had tiny tires and we were not as careful about speed as we are now, partly because we didn't yet know about the limits.
  6. f5moab
    1,423
    467
    May 7, 2013
    Somewhere in Idaho
    Looking at some Palomino trailers a few weeks ago, the tires on some were L rated for speeds up to 75 mph and there were some trailers on the lot (not Palominos) that were rated M for up to 81 mph and they were ST tires.
    I read an article a few months ago that many ST tires are being manufactured to a higher rating.
    I run Yokohama AT tires on my popup and on the interstates around here, I'll cruise between 75-80 mph, if the traffic is light.
  7. Customer
    Customer Well-Known Member
    2,434
    240
    Jun 5, 2014
    Everything you need to know should be on the sidewall of the tire.
  8. tsc
    tsc Member
    813
    Aug 20, 2008
    SW Ontario, Canada
  9. flingwing1969
    flingwing1969 New Member
    343
    Jul 6, 2013
    Not an issue in California as legal trailer towing speed is 55 mph. You did notice I said "legal"?
  10. friartuck
    friartuck Well-Known Member
    2,842
    101
    Nov 1, 2007
    Perry, MI
    What Customer said.
    And more information than you need:
    In 2006, the Michigan Legislature amended the speed limit for passenger vehicles towing trailers. The speed limit was previously 55 mph for any vehicle towing a trailer weighing 750 lbs. or more. This applied even on highways where the passenger vehicle speed limit was 70 mph.
    MICHIGAN VEHICLE CODE (EXCERPT)
    Act 300 of 1949
    257.627 Speed limitations.
    Sec. 627.
    (1) A person operating a vehicle on a highway shall operate that vehicle at a careful and prudent speed not greater than nor less than is reasonable and proper, having due regard to the traffic, surface, and width of the highway and of any other condition then existing. A person shall not operate a vehicle upon a highway at a speed greater than that which will permit a stop within the assured, clear distance ahead.
    (5) A person operating a passenger vehicle drawing another vehicle or trailer shall not exceed the posted speed limit.
    http://www.legislature.mi.gov/(S(2f3ymg3skysoeomdkw5e5vcc))/mileg.aspx?page=GetObject&objectname=mcl-257-627
  11. etrailerJohn
    etrailerJohn Member
    96
    Apr 19, 2016
    Wentzville, MO
    As others have said, your trailer tire's sidewall will give you all of the information needed to determine what speed your tires are rated for. Typically only radial tires are speed rated. We have a short article on trailer tire speed ratings on our site.
    http://www.etrailer.com/expert-10.html
