Tire turbulance
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by Jean-Paul, Jul 13, 2019.
  1. Jean-Paul
    Jean-Paul New Member
    26
    Jul 7, 2019
    I wanted to replace my 5.30-12C’s with new tires. Bought 3 on Amazon.com. Got them home tonight and they are 1 inch thinner than the tires I currently have. A total blunder on Amazons part in my opinion. They are labeled 5.30-12. But don’t measure up. My current tires are 4” depth vs the 3” from Amazon. Hopefully will save someone else the headaches, they were Carlisle. Anyone else with this experience. Now I’m not trusting the 5.30-12 sizing.
  2. WrkrBee
    WrkrBee Well-Known Member
    2,103
    787
    Take it and compare it to one at Northern Tool or Tractor Supply.
  3. rabird
    6,582
    258
    TX
    are you trying to compare mounted/inflated tire to one that is not mounted/inflated?
    megcabra and xxxapache like this.
  4. megcabra
    megcabra Well-Known Member
    1,754
    442
    Aug 12, 2015
    Chapel Hill, North Carolina
    I agree with Rabird once mounted the shape and size will change. Also the Carlisle tread will differ from the Load Star. Here is what the Load Star looks like mounted on my utility trailer. In the end I’d not worry about the tread surface area as much as the load range rating that you have and a C should suffice on most Pop-Ups.
    15BDE03F-F726-4A6E-BA8E-C941FC63C4A3.jpeg B4D44BF2-E096-4825-A540-41C0553B14FB.jpeg 9F63DC6B-5673-4143-96F5-36C9D8949881.jpeg
  5. Jean-Paul
    26
    Jul 7, 2019
    Yes. The tread contact on the road wouldn’t change in my opinion. 3” of tread width is going to stay 3” even when inflated. .?
  6. Anthony Hitchings
    301
    101
    Mar 2, 2019
    just checked my Treadstar bias ply tires - 5.3-12 etc, they are 4" wide across the tread face (it would not change much if deflated)
    Jean-Paul likes this.
  7. SteveP
    SteveP Well-Known Member
    1,410
    376
    megcabra, xxxapache and Jean-Paul like this.
  8. Jean-Paul
    26
    Jul 7, 2019
    Tire shop says the same as everyone here. Inflate it and it will be closer. Picking them up in a couple hours. Will see.
    Thank you everyone
  9. Jean-Paul
    26
    Jul 7, 2019
    Thank you Anthony for checking, I’m going to guess these work out to 3” still once inflated
  10. Jean-Paul
    26
    Jul 7, 2019
    Do you recall how much the load star tires were?
  11. Anthony Hitchings
    301
    101
    Mar 2, 2019
    The Treadstars were/are on my 2003 Aliner Scout Low Profile when we bought it 2nd hand (so I don't have a price for you) , the two road tires were manufactured in 2015 trailer, the spare is a 2018 carcass. The Treadstars did fine on my recent 2,000+ mile trip, even though not inflated to the max sidewall pressure. For off-road use, I left the air pressure as-s and slowed waaay down.
    I would have hoped that there were profile standards for these trailer tires, like passenger tires. Maybe not.
  12. megcabra
    1,754
    442
    Aug 12, 2015
    I paid about $40USD each for them several years ago from a local tire store in Canada. Canadian Tire had the Carlisles for about $10 more otherwise I probably would have wound with them. I see in the US, Northern Tool has them for $36. I’m now in North Carolina and when we replaced our Pop-Up tires last year we went to radials. They were not more money and run really cool with little hub heat. One thing is that they are a bit shorter on the sidewall. Here is the link to that post:
    http://www.popupportal.com/threads/12”-radial-tires-velocity-st145r12-d-8pr.119177/
  13. GrueMaster
    GrueMaster Active Member
    168
    52
    May 22, 2013
    Saint Helens, Oregon
    Honestly, those look much better compared to my tires after last year's camping fun. bad tire.jpg
    Note to all: Check your bearings for proper grease before you go on a long trip.
  14. 1REDBEARD
    1REDBEARD Active Member
    139
    40
    Jun 11, 2019
    FL
    I got rim and tires from Northern Tools. But I would look online at their site... I ended up getting them for 60 a piece because they were on sale online, but not in store. I just showed them the online sale price and they gave them to me for that price... Which to me was a great deal
  15. Buzzard42
    Buzzard42 New Member
    Jun 5, 2019
    I went to the radials when it came time to replace. Had a friends nephew mount and balance them. What a difference!!! Plus the radials are weight rated much higher. Ride is so much better.
    1REDBEARD likes this.
  16. eriefisher
    eriefisher Member
    57
    41
    Jul 17, 2019
    Grand River/Southern Ontario
    As I remember, trailer tires, along with agricultural and industrial tires are not regulated for size. Automotive and truck tires are. There can be big differences in actual sizes across brands and even models with in a brand. If your changing in sets(which is preferred) then it really doesn't matter. Mixed matches can be troublesome with dragging and wondering/sway.
